Old 01-16-2019, 08:10 PM   #1
Couch Height
Hey there skoolie folk!
I'm having trouble determining the height of the wooden couch frame (sans cushion). Was originally thinking 16" and now feeling more like 14", but worried that even that may be too high for comfort. I can't go any lower than 12" due to my fresh water tank.
What dimensions has everyone used for their couches/seats/benches and how what are your feelings after sitting on it? I plan to spend plenty of time on it so comfort is highly important to me...
tcs339 is offline   Reply With Quote
Old 01-16-2019, 08:17 PM   #2
Actually, standard seat height these days is about 17".
Old 01-16-2019, 08:56 PM   #3
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
We built 18" high plus 4" cushions. If I was to do it again, I'd go 14 or 15 high with 4" cushions
Nick
Old 01-16-2019, 09:01 PM   #4
Thanks for the responses. How tall are you fellas?
17" might be standard but I assume that includes the cushion height...? I'm only focused on the wooden frame at the moment.
Old 01-16-2019, 09:02 PM   #5
Ninjakitty's Avatar
I'm 5'5". I like a lower couch
Nick
Old 01-16-2019, 10:47 PM   #6
Go with what fits you.
I'm 6'2" and have always said "ya gotta go with what works for you". I think this works well with couches and crappers. What works for John doesn't work so well with Jane.
That said I believe that if you subtract about 3-1/2" from what your comfort level is, you should end up with a good overall height for your frame. This allows for some "give" in the 4" cushion. Good luck
1olfart is offline   Reply With Quote
Old 01-17-2019, 06:47 AM   #7
Engine: 345 international V-8
For boats, I usually build the seat frames at 14-15" then use 4" high density foam. This will sqeeze down to about 2-3 inchs when sat on.
Whats important is your feet will be able to comfortably be flat on the floor without the seat holding them up any. So this does become a personal thing. If in doubt best to be a little low rather then high.
Old 01-17-2019, 01:48 PM   #8
Thank you! Ronnie I think I'm leaning towards 14"--better low than high is a good tip, worst case I can make the cushion a bit thicker. And 1olfart subtracting 3.5" seems like a great rule of thumb.
PS...open to tips on custom cushions as well if anyone has ideas/experience...
Old 01-17-2019, 07:11 PM   #9
Ninjakitty's Avatar
Find your cushions before you build your couch unless you can sew. Custom cushions get expensive and so does sewing your own really. If you can find some new or second hand couch cushions in good shape you'll save a few hundred or more and not have to go through the hassle of building your own or outsourcing
Nick
Old 01-17-2019, 07:54 PM   #10
Sleddgracer's Avatar
I'm planning on making expandable benches that can double as beds, and use futon mattresses - cost for mattresses $155 upwards
bench, couch, dimensions, seat
