Old 10-04-2011, 07:37 AM   #1
DIY Bump Out
Just wondering if anyone has built their own side bump outs...and how? Any info would be appreciated.
dabauer1701e is offline   Reply With Quote
Old 10-04-2011, 10:36 AM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: DIY Bump Out
If you are talking about a slide out... I have heard of a few coach converters that did. I posted a link to a guy who built a fiver with a slide out (scroll down to the bottom of the page). You need to make sure you beef up the framing all around the opening with cross bracing. and then you will need to deal with all the problems that slide outs develop (leaks, mechanisms messing up, the slide "opening" while traveling down the road, water/debris/ice on the roof of the slide out has to be removed before closing, in cold weather you either find a way to seal the cold out or you keep the slide pulled in as they are HUGE heat sinks...etc). If you must have a slide.. get a slide topper to go with it. It will save you cleaning time every time you close the slide (you have to climb up and make sure there is no debris or critters on the roof of the slide out and under the slide topper). All so that you can gain less than 24" of space. And the mechanism for the slide outs are very pricey. Adding a "hole in the wall" is asking for trouble in my opinion. I've read too many of the RVer's having mega problems with slides. Of course if you have a stressed skin bus, forget it. That's why you don't see many MCIs with a slide out. Stressed skins are integral part of the frame integrity. You don't cut huge holes in the sides without almost rebuilding the frame of the whole bus (floor, roof and opposite wall have to be reenforced along with the wall you cut the hole out).
Fulltime since 2006
Old 10-04-2011, 10:55 AM   #3
Re: DIY Bump Out
Thanks for the info. It seemed to me to be alot more trouble than it would be worth.
Old 10-06-2011, 12:30 PM   #4
GreyEagle's Avatar
Re: DIY Bump Out
Ditto
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 10-06-2011, 02:49 PM   #5
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: DIY Bump Out
You would need to raise the roof first, unless you want an awkard little box. Otherwise go for it, and post pictures. A guy here had built a slide-out that popped out of the rear of the bus. The long and narrow look, just like the classic single-wide.
bump in HP crazycal International | Navistar Drivetrain 2 03-14-2013 05:29 AM
bump frank-id Mechanical and Drivetrains 2 05-20-2012 10:35 AM
bump frank-id Conversion Tutorials and How-to's 1 05-19-2012 08:54 AM
bump frank-id Veggie Oil | WVO | Biodiesel | SVO 1 05-19-2012 08:52 AM
bump frank-id Alternative Fuels | Electric, Propane, Wood Gasification, etc. 2 05-19-2012 08:47 AM
