05-11-2018, 04:12 AM
#21
Under carriage storage
Here’s what I’m doing. I took the old bus seats and cut off the back of them and am in the middle of welding them upside down under the bus. Then I’ll cut and hinge the very bottom outside panel to be a door. I’ll use the seat to be the frame. Then just throw some sheet metal down to make a box. I’ll post some pics when I’m done. By the way I have a 2000?e-450 stripped chassis 21 foot short bus.
05-11-2018, 07:49 AM
#22
great! please take pictures of the building process too.
05-11-2018, 08:01 AM
#23
I'm looking at a similar thing for mine. I have lots of seats and I'd rather use the metal than discard it!
05-12-2018, 01:40 AM
#24
Here some pics so you can see how it looks. The one pic taken from out from under the bus is just to show you where your looking at in the other pics. It’s right after the door and the propane tank I put that there just so you could get some kind of idea of where I put it. I plan to hinge the section below the black line that goes across the outside of the bus to access what ever I end up putting there. Just have to throw some sheet metal down and around it you got yourself some more storage space.
05-12-2018, 06:18 AM
#25
Very creative! good use of materials. did you have to cut the seat legs a bit? I'm trying to find out how much storage that will be when it's all done.
05-12-2018, 09:18 AM
#26
Rated Cap: 35
I love the re-purposed use of seats. please post more (rotated pics) of the progress.
05-15-2018, 05:38 PM
#27
Engine: Dt466e
Rated Cap: 71
Now thats how you repurpose! I would have never thought of that. Very nice!
05-16-2018, 01:35 PM
#28
The endless creativity and ingenuity here are awesome
would love more pics for sure
12-07-2018, 10:22 AM
#29
Chassis: A3 FE
Rated Cap: 78 skinny butts YMMV
Hate to show my ignorance... but...
how did you attach bench frames to the underside of the bus? Weld to the ribs or drill through the floor and put bolts down?
I saved my benches to re-purpose them, but not sure of how to "mount" them to the bus.
04-11-2019, 11:51 AM
#30
Year: 1978
Engine: Detroit 6-71
Hey, I would like to know when adding these frames for under storage, do most of you weld them into the bus frame/chasis or do you drill through floor and bolt?
04-11-2019, 01:57 PM
#31
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
VERY good idea - similar to the not fully formed idea I've had about skirting for aerodynamic reasons and using the skirting to cover storage compartments, acompanied with the specter of buying a lot of angle iron in the back of my mind - using the seat frames is a great idea, and sort of a 'DUH' moment for me with a 'why didn't I think of that?' feeling
04-11-2019, 02:01 PM
#32
Year: 1978
I agree, would anyone have input if these frames or w.e material used to create a storage compartment would have to be welded to the bus frame or would it be bolted (drill holes in frame/floor above and held by bolts)
04-11-2019, 02:13 PM
#33
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
not an easy answer because it would be a case by case situation - cross members would be my first choice - through the floor would be a 2nd but valid choice too
04-11-2019, 04:13 PM
#34
Year: 1978
I also found these that go inside garages on roof...would this also hold up, everything in the kit that is needed to build, at about 100-200 bucks and weight capacity of 600 pounds... I don't think that''s a bad deal if it can resist all the moving, I guess since the steel has holes to mount to a ceiling...it would be best to drill through floor above to hold it, I don't see how I would weld it??
https://www.homedepot.com/p/NewAge-P...0151/205003289
04-11-2019, 04:17 PM
#35
That's a complete bolt together kit. I wouldn't trust it under load and movement of the bus. If you assembled it and then had all the joints welded it would be much more sturdy. The small cross brackets at the top can be bolted through the floor ribs or welded.
04-11-2019, 04:22 PM
#36
Year: 1978
Yeah, I would definitely weld the kit together as much as I can, I was thinking of bolting through the floor above and possibly also welding, so its like double the safety, is that overkill? I will take some pictures of the underside of my crown, cause I don't know what I can weld onto and what I can't, I see one large beam towards the center of the bus and then I see bunch of smaller ones that hold the Marine Plywood subfloor above...am I safe to think that it's okay to weld to those? Does it matter if they are ALuminum or Stell and if the material is Aluminum..in other words can you weld aluminum and steel together, sorry I have no experience with this so I am going to be learning a lot. I will try to get these pictures up tomorrow
04-11-2019, 04:32 PM
#37
When I mounted my propane tank I drilled right up through the cross floor rib and through the floor. Then I drilled a 1" hole in the floor and using my stick magnet pushed the JB Welded bolts in the hole. This way the floor holes will be easy to patch and not have bolt heads or nuts on the floor. Every 3rd brace on the floor is a joint of 2 panels and have a flange you can bolt to.
04-11-2019, 04:38 PM
#38
Year: 1978
ingenious for some reason I was thinking you push these bolts from the outside up into the the floor upstairs..but you did it from the inside down...then you bring up the storage and bolt them outside below the floor with nuts I am guessing am I right?
04-11-2019, 04:47 PM
#39
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
you would have to modify the height of those racks - I doubt there will be close to 4' of clearance under your bus - if you don't weld yourself or have any experience with fabrication, or have the tools to do the job, you will need to hire someone that has skills with both welding and fabricating specialty objects
04-11-2019, 04:59 PM
#40
Year: 1978
I don't have a lot of experience but I'm handy and my father has over 25 years experience in construction residential and commercial and he has experience welding so I think we might be fine I just want to have information on techniques and to weld or just bolt..I'm guessing welding and bolting would be the safest as it would have double the safety in case one fails the other helps even if it's overkill.
