Old 08-04-2017, 01:57 PM   #1
Engine: 444 International/545
Rated Cap: Handicap bus
Do I need to worry about roof skin pulling back?
We are redoing our 01 International/Bluebird. We are cutting out two windows on each side to install RV windows for better visibility. We started cutting and it looks like the roof skin is pulling up/out. Should we screw it to the interior 1x1ish steel header above the cut?
Lbickham is offline   Reply With Quote
Old 08-04-2017, 02:47 PM   #2
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I vote yes.
Maybe hex head tappers with the weather seal, the kind used in metal roofing?
Skipoffools is offline   Reply With Quote
Old 08-05-2017, 02:32 AM   #3
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I see what you mean, it's curling. Might be from the pull-action of the sawzall?
You may wish to attach an aluminum gutter/deflector along that edge to stabilize and direct water outward.
Drip rail
Old 08-05-2017, 07:42 AM   #4
joeblack5's Avatar
Year: 98
personally I would never cut there. If you see all thee rivets in that pattern then that means that that must or could be a stress section. If you cut that top beam out Then that will not be good for the roof integrity.
Be carefull
later J
Old 08-05-2017, 09:37 AM   #5
There is a factory header (1x1ish) that I am leaving. I do want to cut out the section with all the rivets for clearance. I'm hoping screwing the skin to the header will keep that section intact.
