Old 01-13-2017, 08:26 PM   #71
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
if you are planning on a roof unit or a portable unit keeping you cool while driving (running a genny).. you will be disappointed.. make you dashboard A/C and heast work right and use good fittings, proper 134A conversion.. clean it all up nice and it wont be unreliable...
for being parked, you'll want your bus to be greatly insulated to even stand a chance in daytime sunshine... at night a poertable unit in your bus will do the job nicely.. or if you are highly shaded...
swamp coolers are great west of the mississippi but not east (even up north).. unless you like a cool Clammy feeling... gulf moisture makes it north and east... dewpoints in the high 50s even are pushing it for a swamp cooler to not make you feel clammy..
in the west they are fantastic where the dewpoint rarely gets into the 50s. unless it rains.. you can get a lot of cooling for vdery little energy use and wont make the bus too clammy inside...
even in ohio. michigan/ new england you'll see fairly humid conditions in spring and summer.. not much in fall unless you are south of the ohio river..
are you a good ac man chris, I must have moved one of mine the wrong way because it stopped working. not sure if I lost the juice or busted a wire.
my build pics
Old 01-13-2017, 09:44 PM   #72
Chassis: CE
Originally Posted by family wagon View Post
In case you're near the "pay the problem to just go away" point, there's a guy in Denver who does roof raises for hire.
Who is this guy? How do I find him? I'm not at that point quite yet, but I may need to consider this option. PM me if you like.
FuzzWantsABus is offline   Reply With Quote
Old 01-14-2017, 08:37 AM   #73
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Charles_M is his forum name.
$10,000 to raise your roof.
Roll Your Own Build Thread
Old 01-14-2017, 08:40 AM   #74
Chassis: CE
Dear God. I am doing a skoolie because I am NOT made of money. I'm sure it's a good option for some, but I think I'll wait until I'm more desperate.
Old 01-14-2017, 09:13 AM   #75
Chassis: International S3800
I do a lot with A/C's. (used to be my trade till I found out I could make 3X the $$$ programming and installing computers instead of thermostats...)
does your bus have 2 compressors and 2 inside units? or just 1 compressor and 2 inside units?
if they are Trans / AIR and leak their freon out the controller will not allow the unit to start.. not even the indoor or outdoor fans or compressor..
Old 01-14-2017, 10:28 AM   #76
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
I have 2 units and 2 compressors. Both worked. Now on the front unit the blower works. The fans outside work but the compressor does not engage. R 134 systems
my build pics
Old 01-14-2017, 11:17 PM   #77
Chassis: Blue Bird
Engine: ISC 8.3
Yep, that's who I was thinking of. Didn't realize he charges that much. Maybe I should start doing 'em too. It'll only take me 2 years plus or minus to get it done.. Surely the second time would go faster!
Old 01-14-2017, 11:38 PM   #78
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Once Superdave and I raise my roof, and my confidence is higher, I'll gladly raise roofs for folks CHEAP. I'm gona work hard this year to get some property- then ITS ON, folks!
Charles is a HELL of a guy- but I think folks spending TONS of money on these things are missing one of the big points of going the school bus route vs just buying a badass coach.
Old 01-15-2017, 07:06 AM   #79
Most often when a compressor fails to engage it's usually low pressure or a simple wiring issue. Someplace near the receiver / dryer( little canister) there should be a pressure switch on it. If it's 2 wires you should be able to pull off the connector and ohm across the switch terminals .. if you get an open, time to put gauges on it and see if you have refrigerant. If it's a good circuit then start tracing wires from the compressor on toward the control relay panel. Each unit should have a little relay board someplace.. mine for redbyrd was stuffed in the driver switch panel, I've seen others in outdoor accessible compartments. These units are most all aftermarket so the installers can put them anywhere.. and it's easy when ripping wires out for a conversion to cut one..
Christopher
Old 01-15-2017, 07:07 AM   #80
If there's people bidding a rusty dented bus up to nearly 9k then there's people willing to pay 10k for a roof raise
Christopher
floor, heat loss, insulatio
