Old 08-24-2016, 11:50 AM   #1
Coachwork: Thomas Saf-T-Liner
Chassis: Thomas Saf-T-Liner
Engine: Cat 3208
Does floor NEED inaulation
Had a really interesting talk with somebody who said they had a hard time with the snap-together floating floor on their bus. The movement caused the floor to lift. We had originally planned on not doing furring strips, but floating our floor directly on very firm insulation, but we aren't as confident it won't dent the insulation or cause to much give so the floor comes apart.
Heat rises, so essentially we feel that the floor does not lose much heat, and rugs and socks can help with cold feet. The height lost will be put into insulating a ceiling, for we don't want to lose height both directions. We are also super insulating the walls, and running rigid foam UNDERNEATH the bus, instead of the floor. He suggested just gluing The floor onto the metal, but we want a vapor barrier....has anybody done something like this? We don't feel we have the time or resources to do furring strips, nor do we want to lose 3 inches of floor and not have room to insulate the ceiling...
SmujnStar is offline   Reply With Quote
Old 08-24-2016, 01:01 PM   #2
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
We did not change the stock insulation at all in our bus. It does not hold heat well but that is due to the windows, not the floor. Our floor is metal, then we put down vapor barrier and then the thin base foam (can't remember the name of it) that goes under normal laminate snap together flooring. Half of our floor is snap together laminate maple, and half of it is stick on black and white vinyl tile on top of a sheet of luan on top of the aforementioned vapor barrier and foam. I think putting your foam board under the bus will be great for insulation, just make sure it's sealed well so wet from the road can't get in it and make it heavy and moldy and rusty. We've been on the road with our flooring for over 15,000 miles and haven't had a problem. It's not even secured to anything and it doesn't even go all the way to the walls. We just screwed our furniture right down into the floor and that also holds the floor from sliding around without inhibiting the "floating" aspect. And we bought the cheapest (<$1/ft) flooring Lowes carried! Even with no insulation it's basically no different than walking on wood flooring in an old house. Yeah, it's cold but I don't care how much insulation you pack on your bus, if the windows are still there it won't hold heat. We're ok with that and would rather keep our windows and save money on insulation.
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 08-24-2016, 01:54 PM   #3
SmujnStar, As you pointed out, heat rises. You'd be surprised at just how much heat will enter your bus from the floor. Even with the 2" of foam under my bus floor I still see a big climb in interior temps when I park on an asphalt parking lot late in the afternoon. Remember, insulation works in both directions. Installing the under floor insulation was a PITA but I'm sure glad I did. Jack
Old 08-24-2016, 06:27 PM   #4
Jolly Roger's Avatar
Engine: Detroit 8.2
I plan on going the insulation underside route.
A floating floor is exactly that.
If you read the directions it says to cut it 1/8? Short to allow room for expansion and contraction and the trim boards to be installed in the same manner for the same reasons.
I did the whole floating floor in my house before I did my bus.
There are areas in my house that I cut to tight and when we go from AC to windows open the floor likes to bow/buckle in places.
I would think that in a moving platform that you would want to leave even more wiggle room to accommodate the floating in the floor.
To be a thick quarter round or make your own trim is needed.
I built every wall, or whatever to securely fasten directly to the steel floor so all of my spaces are floored separately to wiggle as needed and that's why I decided to insulate underside instead of inside. I used 1/4" foam for most and and little bit of some carpet underlay that was fibre material with plastic for around the transmission motor area? Trying to deaden the sound a little.
Hope this helps.
Sorry another option I just started daydreaming about was clean/prep and spray foaming the underside?
It would be easier and maybe cheaper before you put a lot of mess in the way.
I do commercial construction and see them spray galvanized metal and they can do a 3" spray on the backer board the steel I-beam then to the wall and then a 8" stud and never touch wher they don't need to. .
Hope this helps
Old 08-24-2016, 06:34 PM   #5
In my little storage building cabin here in Oklahoma... All it had was 3/4" plywood floor and a few throw rugs. The walls & ceiling were well insulated and I kept warm with a quartz heater most nights, and on the coldest nights I added the milk house heater.
I think the biggest helper was circulating the air with a fan.
Most often, the Quartz Heater's thermo was set maybe 1/2 way.... BUT, this is Oklahoma and probably didn't get below 25° this last winter.
As a temporary cure, I've added 1" Foamular over my bus winders and 1/2 of my walls... Insulating a rear OSB stud wall and a forward OSB stud wall with fiberglass now
Old 08-24-2016, 08:07 PM   #6
with any kind of wood product used in an area of changing climate you need to leave some room around the edges for it to expand and contract... as noted in the post above..
I also believe in a bus any snap together type flooring might cause an issue as the bus flexes.. sheet flooring and stick down squares dont snap together so they can move around.. putting your foam under the existing bus floor seems quite difficult..
my bus still has its bone stock original metal floor covered by its OEM plywood then the rubber.. i get some heat from the floor but even on the hottest days my floor is never that warm... I havent had the bus in winter yet so I dont know how much cold ill have from the stock floor..
the windows are the culprit for keeping my A/C from making it an icebox... when the sun is out I feel the temperature rise a lot.. when the sun goes behind the clouds it drops.. my bus is all stock.. I drive it all over the place this way... since mine is mainly a road bus i dont worry about how much energy i use heating or cooling.. unlike what you are likely to do.. but if it were mine to make into a camper i would insulate everythign I could while building it out.
Old 08-25-2016, 08:46 AM   #7
Chassis: B3800 Short bus
Just a quick note: the metal floor is a vapour barrier. Adding an extra vapour barrier - such as sheets of poly - is actually making a vapour barrier sandwich, which is generally a bad idea. If condensation occurs, or water leaks down then capillary action will carry that water all over the floor and it will have no way to escape.
Rigid foam is almost a vapour barrier, but does allow moisture to migrate through, which is a good thing. In my opinion, it's the best thing to put directly over the metal floor since it will very slowly absorb and migrate moisture upwards.
I put 2" of rigid foam down before putting plywood on top and it has worked gang busters. It's especially noticeable in the winter. Insulation under the bus is a neat idea, but it will be less effective than insulation indoors since the metal floor is a big heat sink that wants to transfer heat energy to the outside walls. Still better than being uninsulated, though!
Oh, and don't worry about crushing that XPS foam. It's tough stuff. Put some plywood on top of it before the final flooring and it won't ever crush.
Old 08-25-2016, 11:21 AM   #8
What about noise issues? I was thinking about heat AND sound when I insulated.
Tedd is offline   Reply With Quote
Old 11-04-2016, 10:00 AM   #9
BuSmith's Avatar
My Dad did spray foam insulation on the um underside of our original bus as Jolly Roger mentioned. It's been great fit the last 35 years and we're planning on doing it to the current Bus. Has anybody else done it recently though?
Sent from my XT1575 using Tapatalk
BuSmith is offline   Reply With Quote
Old 11-04-2016, 10:17 AM   #10
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
About ready to start my interior, I have about a 2 in plywood floor that I painted with redguard, I'm planning on putting 2 1/2 in of rigid foam board then 3/4 plywood subfloor on top of that what are thoughts ??
Old 11-04-2016, 10:24 AM   #11
BuSmith's Avatar
All I know is what we did. I'm mostly here to try and learn more about y'alls method through osmosis.
Old 11-04-2016, 10:55 AM   #12
It's been mentioned that heat rises.
HEAT DOES NOT RISE.
Hot AIR rises.
ennonne is offline   Reply With Quote
Old 11-04-2016, 11:14 AM   #13
HEAT DOES NOT RISE.
Hot AIR rises.
It's also been mentioned that speed kills,
I contend it's the uncontrolled stop that does it.
Old 11-04-2016, 11:34 AM   #14
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Just like falling doesn't kill...just that sudden stop at the end.
Captain Obvious on deviantArt
Old 11-04-2016, 11:43 AM   #15
Rated Cap: Your mom +1
but what if you have a heart attack on the way down before you hit?
Old 11-04-2016, 12:22 PM   #16
warewolff's Avatar
Ugh ... this is so wrong. Can't we go and reference the other eighty posts that address this exact topic? Yes, heat rises, but that floor is a great thermal bridge to the outside. You will be pretty cold (or hot) depending on where you live.
Generally, heat loss in a home:
Roof/attic – 25%
Windows and doors – 25%
Walls – 35%
Floor – 15%
But a bus is a tin can ...
I don't understand how people can do all their due diligence in researching a topic only to come to the wrong conclusion. Those figures on a home take into account you are using home materials and home insulation. Fiberglass insulation with air gaps. 2x4's. insulation on the outside AND inside. Check THESE recommendations out ... You will be lucky to have an insulation value of R1 or R2 with your plan.
The floating floor is half assed. That foam is really not supposed to hold all the weight people are putting on it. Check the ratings and you'll see. Ever stood on top of a foam cooler? Why not? Right, because it's foam. And it's not meant to support your weight. Some have done the floating floor right and used supports ... most haven't. To each his own. Take the best from both concepts and just frame like you normally would, but glue it down instead of screwing it in to prevent thermal bridging. Then put in your insulation, tongue and groove plywood over that, and floor over that. You'll lose maybe 2 inches if you skimp, 3-4 if you go overboard. It'll feel much warmer. You are looking at a potential R value over 10 if you use the right materials.
Id never put spray foam under my chassis. It's too clean and beautiful to mess it up. Then it's going to get wet and eat away at my perfect frame. Some have done it with success. I tinker around with too much underneath to ever dream of coating it in that gunk.
warewolff is offline   Reply With Quote
Old 11-04-2016, 12:26 PM   #17
FWIW-My house has a big Florida room that's basically a slab with tiles. In the "winter" here, the room is VASTLY colder than the rest of the house, which has floors that are better insulated.
Old 11-04-2016, 12:30 PM   #18
All of the good build threads here provided all the info I needed when deciding how to build my floor.
I used 2x4s on edge to create a framework, then filled the gaps in the frame with 3.5" of rigid insulation(only 3.5" because an actual 2x4 measures something like 1.75x3.6. Laid 23/32" tongue and groove osb on top and then my 12mm laminate flooring with backing pad ontop of that... Solid as a rock and well insulated for both summer and winter.
Don't skimp on insulation if you plan on spending alot of time in your bus.
Old 11-04-2016, 12:40 PM   #19
warewolff's Avatar
And I'd bet you have zero issues with your tongue and groove laminate flooring coming up or warping.
Old 11-04-2016, 12:41 PM   #20
therers a reason why your feet used to freeze in the old Jeeps before they started actually insulating the floors better...
im not sure the R-value but I can say if you are crazy worried about ceiling height that even dynamat helps some with heat loss... likely over-kill for a whole bus floor due to the cost and weight.. but it does help..
floor, heat loss, insulatio
