Old 12-02-2015, 04:10 PM   #1
Chassis: MVP SAF T LINER0
Engine: cat
Electical system how to??
Ok so I got a converter do i need a inverter too? I'm planning on running solar panels instead of a generator. I'm planning on having Washer/dryer, fridge, A/C, and lights those are going to be my only main electrical out puts.
someguy is offline   Reply With Quote
Old 12-02-2015, 05:01 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Get some LED lighting strips from http://WWW.superbrightleds.com They run on 12VDC and don't draw much.
Old 12-02-2015, 06:58 PM   #3
washer and dryer, a/c running on solar? not going to happen unless you got a big ass system. A converter takes 120 volts and changes it to 12volts, and has a charger built in. A inverter takes 12volts and converts to 120volts, so yes you would need one.
