Old 12-13-2017, 11:03 AM   #1
mikerox's Avatar
Coachwork: Bluebird Bus Co.
Electrical panel location
I have a 40 foot Bluebird rear pusher where is the best place to locate the electrical distribution panel front middle or rear and why? TIA
mikerox is offline   Reply With Quote
Old 12-13-2017, 12:14 PM   #2
Chassis: Saf-T-Liner MVP ER
As close to the batteries as possible.
You will have some high-current 12V wiring. It's expensive and you need to kee the losses as low as possible, so keep those wires short if you can.
Steve Bracken
Build Thread
Old 12-13-2017, 12:31 PM   #3
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
He didn't specify electron-type. Are they alternating all around; or are they taking a more direct approach?
RV campsites usually have shore power hookup on drivers side.
Old 02-18-2018, 08:11 PM   #4
+1 on keeping wires from batteries to electrical distribution to save cost and reduce voltage drop.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
