Old 11-23-2015, 07:47 PM   #21
First off, sorry to bump an old thread.
Second, I've searched around and haven't found much about people mounting a PTO style compressor on a bus. Has anyone here done this?
Yes, its most likely overkil but my skoolie is still in the dream stage so why not dream big?
dowster is offline   Reply With Quote
Old 11-24-2015, 12:19 AM   #22
Engine: 190hp 5.9 Cummins
Bumping a old thread like this is good.
There is no PTO on 99% of buses.
Also, there would be no advantage to running the compressor off a PTO vs off the front belt system. If you need more air volume, run two compressor heads.
Old 12-16-2015, 10:14 PM   #23
York Compressor for On-Board Air
perryT200 is offline   Reply With Quote
Old 12-16-2015, 10:55 PM   #24
I built a York on a street legal rock crawler about 20 years ago. Worked awesome! I even used a pressure switch just like the ones on shop air compressor so it would shut off and unload the compressor when air was built up and then it would kick back on when the air in the tanks dropped down. I had a couple of $7 air tanks from Wal-Mart tucked up under the bed.
Eric
daddyoften is offline   Reply With Quote
Old 12-16-2015, 11:02 PM   #25
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
$7, Walmart, and air tank......I'm pretty sure those words aren't supposed to go together!
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 04-05-2016, 02:30 PM   #26
I use these for the show trucks I build. Each truck gets its own compressor and is tons cheaper, quieter, and puts out equivalent or higher air than ViAir or Air Zenith, which are the only two brands of electric 12 volt compressors ill even touch. They are capable of very high psi. I ran the air system on my truck at 250 psi and it would build from 0-250 in about a minute and a half on two 3 gallon tanks.
jbohall001 is offline   Reply With Quote
Old 04-05-2016, 06:37 PM   #27
Jolly Roger's Avatar
Engine: Detroit 8.2
Shreveport? I was born and raised just across the line in Kilgore,tx.?
Have you ever been across the line on I-20 (Marshall,Longview,Tyler)?
Old 04-06-2016, 12:10 AM   #28
Nice! Yea man Im all over these parts. Especially between here and Dallas. Worked in Longview for a while. Close friends live in Tyler so I visit there often.
Old 07-21-2019, 08:16 PM   #29
Originally Posted by Hank's P-O-S View Post
...positive pressure water system...
Did that ever come to fruition? How'd it work out? Had considered it as well.
KalamariSafari is offline   Reply With Quote
Old 07-21-2019, 08:39 PM   #30
HazMatt's Avatar
Chassis: IH 3800, 8 window
Need a way to differentially pressurize the tank, to avoid hand grenading it.
Thanx for bumping this thread back into the light!
One more thing I didn't realize I need, but ought got have...
Old 07-21-2019, 09:00 PM   #31
so i take it this is for those without air brakes or air suspension? those Bendix Air compressors factory installed are 11-17 CFM depending on the model.. more than enough to run most air tools
Old 07-21-2019, 09:08 PM   #32
Originally Posted by HazMatt View Post
...differentially pressurize the tank, to avoid hand grenading it...
Is this in response to multiple reservoir setups, or am I missing something? Or are you referring to the notion of a positive pressure water reservoir? My assumption was that you would pressurize to drive water to your highest outlet, in respect to your systems pressure capacity.
so i take it this is for those without air brakes...
Having found this old thread just this evening, I respond respectfully: I believe that premise was in the OP. Personally, I'm here because I have hydraulic brakes, and own only 12v compressors
Not sure which periodical maintenance item I would prefer - air brakes, or belt-driven air pump...
Old 07-21-2019, 11:45 PM   #33
HazMatt's Avatar
Responding to your truncated quote regarding water pressure.
Without some way to maintain low head pressure in a fresh water vessel, it will quickly pop like an over-fed tick.
And ain't none of us wanna see that.
Is this in response to multiple reservoir setups, or am I missing something? Or are you referring to the notion of a positive pressure water reservoir? My assumption was that you would pressurize to drive water to your highest outlet, in respect to your systems pressure capacity...
An on-demand, engine-driven compressor would be a handy thing to have on a picnic..!
Old 07-22-2019, 12:45 AM   #34
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
direct line from the compressor with a regulator set at 30 lbs or what ever pressure you desire to your water tank would provide reliable constant pressure at the tap - you could still have decent water pressure as your air pressure gradually bled off when you ran the water for quite a while before you had to run the engine again
Old 09-10-2019, 10:10 AM   #35
lqdchkn's Avatar
FNG here so rather than make a typical intro thread first post (I'll get to that later) I'll start here. Stumbled on this topic and was curious about the oiling and hadnt seen anything mentioned in the thread about how to service these. Searched a bit and found this PDF and had to share.
***Had to break up PDF due to forum file size limits
lqdchkn is offline   Reply With Quote
How to Adust Air Brakes ( Check Brakes ) lapeer20m Conversion Tutorials and How-to's 6 10-04-2013 02:10 PM
Anyone (else) using Compressed Natural Gas? Skunky Bus Alternative Fuels | Electric, Propane, Wood Gasification, etc. 1 09-15-2012 08:45 PM
anyone know about propane driven buses? luckyone Everything Else | General Skoolie Discussions 4 07-31-2011 03:15 PM
RE: BUS WITH AIR BRAKES AND TRAILER WITH ELECTRIC BRAKES? XE1UFO Conversion General Discussions 3 07-21-2010 12:55 PM
Belt driven Generators crispyx Conversion General Discussions 5 10-29-2007 10:30 AM
