Old 04-13-2008, 08:35 PM   #1
1993bluebird's Avatar
Chassis: ALL AMERICAN
Engine: 3116 cat / AT 545
Rated Cap: 48
EXHAUST BRAKE
I HAVE A 5 INCH EXHAUST PIPE AND I BOUGHT A 5INCH EXHAUST BRAKE USED OFF EBAY AND I WANT TO KNOW IF I HOOK IT UP WITH A MANUAL SWITCH DO I HAVE TO HAVE A CONTROL FOR THE TRANSMISSION TO LOCK UP THE CONVERTER OR CAN I JUST RUN IT WITHOUT. CAN ANYONE HELP.
1993bluebird is offline   Reply With Quote
Old 04-15-2008, 02:58 AM   #2
Re: EXHAUST BRAKE
Well we drive buses out here with 4 stage retarders. They are not exhaust retarders though. They're look like huge alternators that wrap around the driveshaft. Not really sure how they work. Telma is the make. Let me know how your exhaust retarder works out. I do a lot of mountain bus driving.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 05-10-2008, 04:39 PM   #3
Re: EXHAUST BRAKE
How did it work out?
Old 05-10-2008, 06:29 PM   #4
the_experience03's Avatar
Re: EXHAUST BRAKE
I hate to be the bearer of bad news, but an exhaust brake will be about as effective as sticking your hand out the window on a bus with an AT545. Exhaust brakes rely on the torque converter clutch to keep the transmission from just over-running the engine. On top of that, you really would want to have the bus manually downshifted so as to bypass any overrunning sprags in the transmission itself to get the FULL benefit of the exhaust brake.
Old 05-11-2008, 06:21 PM   #5
Re: EXHAUST BRAKE
I drive for a school district where we're in the high mountains. All out buses have Telma retarders. They are electromagnetic and work great. Most of them are 4 stages with a lever to activate it near the steering wheel. In the snow it's like having a hand brake on the bus, good for freestyle bus driving. No one tell my boss! Oh yeah and the kids aren't on the bus when I'm screwin around either. Have to be careful with them though when it's icy out cause that rear will slide.
Old 05-11-2008, 06:45 PM   #6
phillbus914's Avatar
Re: EXHAUST BRAKE
Think of the energy that could be harnessed from those. Sorta like a hybrid car. Could be a cool way to charge a battery bank.
My Old Bus :(
Old 05-11-2008, 10:50 PM   #7
lapeer20m's Avatar
Re: EXHAUST BRAKE
we have one of those telma aux braking systems in some old ambulance.
ours is also four stage. i don't really know how it works, but i always assumed it had a regular disk brake on the driveshaft, but used an electromagnetic actuated caliper on it......
now i'm really curious
how does that thing work?
Old 05-12-2008, 12:12 AM   #8
Re: EXHAUST BRAKE
They work like a shorted alternator to the best of my knowledge. Basically they make electricity which they turn into heat. Locomotives use a similar concept. I'm with Phill on that one. Diesel-electric hybrids actually make sense for buses, especially school buses and city transit buses.
Old 05-12-2008, 11:10 AM   #9
Re: EXHAUST BRAKE
Has anyone hooked up an alternator of sorts to the driveshaft to generate power for a battery bank? Sounds like a feasable concept.
Old 05-12-2008, 09:30 PM   #10
Re: EXHAUST BRAKE
I'm sure you could, but hooking it to the engine seems a whole lot easier and will have the same effect.
Old 05-13-2008, 10:25 PM   #11
Re: EXHAUST BRAKE
How many amps is a typical alternator in a bus? Is there a maximum size you can put in?
Old 05-22-2008, 03:19 PM   #12
Re: Hybrid School Bus
check this out, apparently they're testing a few hybrid school buses around the US right now.
http://www.advancedenergy.org/corporate ... tives/heb/
My Old Bus :(
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Bus exhaust catalog somewhereinusa Conversion General Discussions 0 03-09-2012 07:46 AM
CAN SOMEBODY TELL ME PLEASE HOW TO INSTALL EXHAUST BRAKE? XE1UFO Cummins Drivetrain 4 06-03-2011 09:39 PM
open exhaust on a 5.9 ? Elliot Naess Cummins Drivetrain 4 12-26-2010 04:01 PM
Exhaust brake for gasoline engines rabiznick Conversion General Discussions 0 08-07-2005 08:03 AM
