03-18-2017, 10:30 AM
Exterior electrical box?
Hello, I haven't cut the hole for it and i am wondering how do i make the box stationary to the exterior wall panel?
03-18-2017, 10:44 AM
Where do you want to pt it? Flush or recessed? Can you drill a hole where you want it to come out?
Be versatile.
03-18-2017, 12:13 PM
Rated Cap: 19
What sort of box is it? Most put their shore power connector at the back of the bus on the driver's side.
03-18-2017, 01:11 PM
Not shore power. I just want a plug in electrical box on the right side about 6 ft back from the door. I think i figured it out. I will ad a 2x4 on the inner wall with the 4" face against the wall. I cut out the inner wall and a blue old work box comes out flush with the 2" of the 2x4 and i will glue it to it.
Any one with a better way please tell me. I usually see a better or the right way after i have already done it.
03-18-2017, 01:21 PM
Just to clarify, is this to be an inside or outside outlet? Unclear what you want but sounds like you need help.
03-18-2017, 01:32 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I am not sure of your preference, but why not an exterior electrical box that has weather resistant doors? Have them on my house. At home I wouldn't think of recessing an exterior electrical box, too big a hole in my house. But a small hole for a piece of conduit that is less difficult to seal I don't mind.
Benefits are a smaller hole.
And no interior structure need be added
Cons are it's bigger and it's more visible. On a mobile application it sticks out. I don't have to park my house lol
03-18-2017, 01:53 PM
I have a flush mount waterproof cover. I want it flush with the side of the bus.
03-18-2017, 01:54 PM
It will be an outside outlet with a waterproof cover.
03-18-2017, 02:02 PM
Rated Cap: 19
03-18-2017, 04:00 PM
You haven't said what type of wire you are planning on using. I hope not that housewire plastic?
Get some 12/3 bx (armoured cable, some anti-shorts and connectors,) of what length you figure, maybe just back to back with the inside receptacle.?
BX cable provides all the mechanical protection you'll need if installed proper.
A nice box for this looks ordinary but has a 1/4" or 3/16"into a clamp that runs into a bracket behind the box. Looks like the "M" of the hamburg joint.
You cut the whole for the box pretty exact and plumb level. That M draws against the wall around the hole that the box is in.
Don't even need a helper to do this.
Most ask why #12 and it's pretty well known that extension cords do get pretty loaded up with amperage. When that happens the 12 wire can carry the excess draw of amps to a limit of 20. If the breaker doesn't pop,
the 12 won't overheat in such a hurry as #14. Thank god breakers work in milliseconds when overloaded. Safety first. your outdoor cover will fit flush and should have a gasket on/with it. Use it.
03-19-2017, 08:46 AM
Thanks. Exactly what i wanted. Will get a box this morning.
