Old 05-04-2016, 11:09 AM   #21
Chassis: Ford E450 Super Duty
Engine: V8 6.0
Rated Cap: 30 animals and 1 human
Originally Posted by dredman View Post
so the storms came at 4am, so I dragged my ass out of a warm bed to see the drips, and if I had conquered The Holy.
Results:
Front drip over the dash? GONE
3rd Passenger wind drip? GONE
2 of the 4 rear leaks? Gone, but only 2 of them.
the 2 remaining drips are most likely due to the fact I skipped some rear seams, and was stingy on the other rear seams to conserve the 212 - yes, I knew what I was doing. So I have to crawl back up there, but at least I am confirming the 212 works.
Could you possibly give me the specifics about the materials you used to fix the leak? I've heard a bunch of input about different types of sealants but since I'm doing the exact same job as you did I'll definitely try the same. Thanks!!
sinapu is offline   Reply With Quote
Old 05-08-2016, 12:49 PM   #22
dredman's Avatar
My Skoolie Story on YouTube
dredman is offline   Reply With Quote
Old 05-08-2016, 01:15 PM   #23
Jolly Roger's Avatar
Engine: Detroit 8.2
I am sold on sono-lastic NP--1 and can order in any color but any caulking not if but when you get it on you it loves a plastic bag (like from the grocery store) or baby oil will get it off of your skin before it dries (don't ask for details)
If exterior don't leave a bead of caulk? Wipe it down down smooth. The paint going over it will crack and peel at every caulk joint so no more than what you need and a spray bottle of baby oil and water mix to spray your small putty knife or your middle finger once you get used to using it properly will go along way. I can guarantee you if you use NP-1 on anything you don't want to take apart but end up having to? You will muck the joined pieces up before it comes apart.
Old 05-08-2016, 03:36 PM   #24
Engine: V8 6.0
Thanks so much for the reply, I can't seem to find anything to patch it with, NAPA has larger pieces of aluminum for 25.00 guess I'll just get one of those..
Old 05-08-2016, 06:09 PM   #25
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
bring your snips to the dump with ya next time and cut a side panel of washer, dryer, dish washer door, something of that nature will make a good patch.
The road is crazy.
Be safe
Arvik is offline   Reply With Quote
Old 05-08-2016, 06:15 PM   #26
Engine: V8 6.0
I guess I should've thought of that. Thanks
Old 06-21-2016, 01:04 PM   #27
rjnye79's Avatar
Engine: T444e
Has anyone used FlexSeal or comparable product on their roof seams/rivets? ...or perhaps a roll on bed liner?
rjnye79 is offline   Reply With Quote
Old 06-26-2016, 09:53 AM   #28
rjnye79's Avatar
Engine: T444e
Come on y'all... I gotta believe SOMEONE has tried this stuff.
Old 06-26-2016, 07:09 PM   #29
Best bet is to clean the roof thoroughly...then hit every seam with OEM grade automotive Seam Sealer...then a couple of coats of a good elastomeric (rubber) paint. Preferably white.
Old 06-27-2016, 12:54 PM   #30
rjnye79's Avatar
Engine: T444e
Thanks Tango... Are there any particular products that you're familiar with?
Old 06-27-2016, 12:59 PM   #31
rjnye79's Avatar
Engine: T444e
Also, can the elastomeric paint go over the whole roof? Is it okay to paint over elastomeric sealant with said paint?
Old 06-27-2016, 03:24 PM   #32
Two-part spray on bed liner has been used for years to seal RV roofs. It is not cheap but it is by far the most durable method in existence. After applying the liner, you go back over it with a few coats of a white heat barrier paint. You might have to re-do the paint from time to time, but the liner is much tougher than needed for that application and will be there forever!
Don't know much about the roll on liner material, other than the fact(s) that (as with any single component material) it is much weaker and considerably less durable - enough so that I wouldn't use it.
BlueBirdman is offline   Reply With Quote
Old 06-27-2016, 03:30 PM   #33
I know BusKote can be painted over.
Its good stuff but very pricey.
Old 06-27-2016, 03:45 PM   #34
rjnye79's Avatar
Engine: T444e
Alrighty, good to know... Thanks guys!
