Old 06-27-2016, 12:59 PM   #31
rjnye79's Avatar
Engine: T444e
Originally Posted by Tango View Post
Best bet is to clean the roof thoroughly...then hit every seam with OEM grade automotive Seam Sealer...then a couple of coats of a good elastomeric (rubber) paint. Preferably white.
Also, can the elastomeric paint go over the whole roof? Is it okay to paint over elastomeric sealant with said paint?
rjnye79 is offline   Reply With Quote
Old 06-27-2016, 03:24 PM   #32
Originally Posted by rjnye79 View Post
Has anyone used FlexSeal or comparable product on their roof seams/rivets? ...or perhaps a roll on bed liner?
Two-part spray on bed liner has been used for years to seal RV roofs. It is not cheap but it is by far the most durable method in existence. After applying the liner, you go back over it with a few coats of a white heat barrier paint. You might have to re-do the paint from time to time, but the liner is much tougher than needed for that application and will be there forever!
Don't know much about the roll on liner material, other than the fact(s) that (as with any single component material) it is much weaker and considerably less durable - enough so that I wouldn't use it.
BlueBirdman is offline   Reply With Quote
Old 06-27-2016, 03:30 PM   #33
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I know BusKote can be painted over.
Its good stuff but very pricey.
Roll Your Own Build Thread
Old 06-27-2016, 03:45 PM   #34
rjnye79's Avatar
Engine: T444e
Alrighty, good to know... Thanks guys!
