04-21-2015, 07:35 AM
Finding roof leaks
Heavy rains last week demonstrated some issues, and it looks like most are seams, as they all stopped when I moved the bus uphill - all but one. The one dripping on to the driver's dash. The primary suspect is this guy. Not sure what it is or purpose, or even what problems I will cause if I caulk it/remove it?
04-21-2015, 07:49 AM
That should be a vent to let bus breathe, on mine when I removed it, it had a lip upwards about 3/8 inch high, so a leak from there not likely UNLESS the rivets are leaking
can you look inside of it and see if it has a lip?
04-21-2015, 08:25 AM
Chassis: I.H.
Spray some koolaid on the suspected leak spot and see if the color appears inside. Just my 3 cents.
04-21-2015, 08:52 AM
not sure how to look inside of it?
this is what it looks like on the inside.... directly below
looks like mold?
04-21-2015, 09:01 AM
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I had one of those. Supposedly it is to allow air in / out for expansion and contraction of the air when the bus is in the sun and for day / night or whatever. Unless your bus is super airtight I don't think it is necessary. I took mine out and patched over it. No issues yet. Mine had that nasty mold under it on the panel not necessarily from leakage but probably just years of air / condensation coming through.
To find leaks, I simply went out in the bus when I had the interior totally stripped (ceiling panels out too) during a heavy rainstorm and made sure I had some bright halogen lights on inside. I had probably 6 or 7 different leak spots on mine, several from the roof hatches which I replaced with units from another member here and resealed. Some were leaky rivets which I just gobbed silicone over. Others were seams at the sheet metal. I used some gooey rubber roof caulk from Home depot to seal ALL seams on the roof (if you PM me to remind me I will link it to you). Finally, I used elastomeric roof paint to paint the roof white (heat reflection) and used a 4" brush over the riveted areas on the roof, and just slathered the pain on there real thick. All the other areas I just rolled it. That took care of all but one of my leaks which came from a side panel gap in an area where a lot of water was running down the side of the bus. That one I just undid / broke off the screws (Thomas built bus which uses screws instead of rivets in many places) and riveted it into place with some automotive seam sealer.
04-22-2015, 06:43 AM
so I simulated a repair, and a rainstorm yesterday, with no leaks. Maybe I will leave the repair and wait for the next rainstorm? I hesitate only because I fear results of removing the vent. Would that not cause MORE moisture?
04-22-2015, 06:50 AM
I have a similar vent that leaks horribly.
My solution was to buy a new rv roof vent. Yeah it requires cutting. But I figure one can't have too much ventilation.
04-22-2015, 08:43 AM
Engine: 190hp 5.9 Cummins
Just remove that that roof vent. It's not needed.
You would be better off adding a vent in the rear cap of the bus at the highest point.
04-24-2015, 04:15 PM
Well I got to cuttin and pryin today........
then I had to administer a beat-down, to make the roof "flush" for the new patch.
post beat down
patch installed, lotsa sticky jelly underneath and around edges
remnants
results tomorrow after the storms
04-24-2015, 05:08 PM
Great pics.
I like the steps shown in pics form.
04-25-2015, 06:13 AM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
great job,doing the same to mine
04-25-2015, 09:26 AM
so the storms came at 4am, so I dragged my ass out of a warm bed to see the drips, and if I had conquered The Holy.
Results:
Front drip over the dash? GONE
3rd Passenger wind drip? GONE
2 of the 4 rear leaks? Gone, but only 2 of them.
the 2 remaining drips are most likely due to the fact I skipped some rear seams, and was stingy on the other rear seams to conserve the 212 - yes, I knew what I was doing. So I have to crawl back up there, but at least I am confirming the 212 works.
05-03-2016, 03:25 PM
Chassis: Ford E450 Super Duty
Engine: V8 6.0
Rated Cap: 30 animals and 1 human
Thanks for your post Dredman ,I'm going through the exact same thing with mine and was debating about the vent and if it had a purpose.
05-03-2016, 05:19 PM
I just do what I am told
05-03-2016, 06:03 PM
So do you take instruction from just about anyone or only Mrs dredman or dredwoman?
05-03-2016, 08:56 PM
HAHA, not back then, that might be why she split?
05-03-2016, 11:03 PM
That seems to be the theme in most of our lives.
I'm happy to be free again. Free like a salmon that finished his work.
05-04-2016, 06:00 AM
When my 1982 model started making too much noise I traded her in for a 92' with a lot less miles.
05-04-2016, 08:57 AM
Noise was never a real problem with my old '74, she just smoked a lot, and just sat there when you stepped on the gas? But she was comfy - maybe TOO comfy. It got so comfy in fact, it was hard to even get in past all the thick upholstery. Currently looking for a newer, more responsive sports model with low miles.
05-04-2016, 10:13 AM
My 59 thought she was just as good as a newer model. Same equipment my butt.
