Old 04-21-2015, 07:35 AM   #1
dredman's Avatar
Finding roof leaks
Heavy rains last week demonstrated some issues, and it looks like most are seams, as they all stopped when I moved the bus uphill - all but one. The one dripping on to the driver's dash. The primary suspect is this guy. Not sure what it is or purpose, or even what problems I will cause if I caulk it/remove it?
dredman is offline   Reply With Quote
Old 04-21-2015, 07:49 AM   #2
That should be a vent to let bus breathe, on mine when I removed it, it had a lip upwards about 3/8 inch high, so a leak from there not likely UNLESS the rivets are leaking
can you look inside of it and see if it has a lip?
Old 04-21-2015, 08:25 AM   #3
Chassis: I.H.
Spray some koolaid on the suspected leak spot and see if the color appears inside. Just my 3 cents.
Old 04-21-2015, 08:52 AM   #4
dredman's Avatar
not sure how to look inside of it?
this is what it looks like on the inside.... directly below
looks like mold?
Old 04-21-2015, 09:01 AM   #5
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I had one of those. Supposedly it is to allow air in / out for expansion and contraction of the air when the bus is in the sun and for day / night or whatever. Unless your bus is super airtight I don't think it is necessary. I took mine out and patched over it. No issues yet. Mine had that nasty mold under it on the panel not necessarily from leakage but probably just years of air / condensation coming through.
To find leaks, I simply went out in the bus when I had the interior totally stripped (ceiling panels out too) during a heavy rainstorm and made sure I had some bright halogen lights on inside. I had probably 6 or 7 different leak spots on mine, several from the roof hatches which I replaced with units from another member here and resealed. Some were leaky rivets which I just gobbed silicone over. Others were seams at the sheet metal. I used some gooey rubber roof caulk from Home depot to seal ALL seams on the roof (if you PM me to remind me I will link it to you). Finally, I used elastomeric roof paint to paint the roof white (heat reflection) and used a 4" brush over the riveted areas on the roof, and just slathered the pain on there real thick. All the other areas I just rolled it. That took care of all but one of my leaks which came from a side panel gap in an area where a lot of water was running down the side of the bus. That one I just undid / broke off the screws (Thomas built bus which uses screws instead of rivets in many places) and riveted it into place with some automotive seam sealer.
porkchopsandwiches is offline   Reply With Quote
Old 04-22-2015, 06:43 AM   #6
dredman's Avatar
so I simulated a repair, and a rainstorm yesterday, with no leaks. Maybe I will leave the repair and wait for the next rainstorm? I hesitate only because I fear results of removing the vent. Would that not cause MORE moisture?
Old 04-22-2015, 06:50 AM   #7
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I have a similar vent that leaks horribly.
My solution was to buy a new rv roof vent. Yeah it requires cutting. But I figure one can't have too much ventilation.
Old 04-22-2015, 08:43 AM   #8
Engine: 190hp 5.9 Cummins
Just remove that that roof vent. It's not needed.
You would be better off adding a vent in the rear cap of the bus at the highest point.
Old 04-24-2015, 04:15 PM   #9
dredman's Avatar
Talking
Well I got to cuttin and pryin today........
then I had to administer a beat-down, to make the roof "flush" for the new patch.
post beat down
patch installed, lotsa sticky jelly underneath and around edges
remnants
results tomorrow after the storms
Old 04-24-2015, 05:08 PM   #10
Great pics.
I like the steps shown in pics form.
