Old 07-18-2017, 09:48 PM   #1
Coachwork: Terra Transit, New Paris, IN
Chassis: Ford E350
Engine: 5.5 L V8
Floor Help!
Hi all,
I finally stripped the floor and walls to find some damage from a couple leaks. We drive a Ford E350 a former shuttle bus for an old folks home.
Any who, the floor is plywood with metal strip underneath.
Instead of taking out all the wood I was gonna chop out the rotted wood and patch the areas then attach them to the under frame.
I am wondering to frame or not to frame, insulate, cover with plywood and then put tongue and groove wood flooring? IS there a simpler way?
What should I use to frame the floor? What about insulation?
Any advice would be wonderful!
Q'willWorks is offline   Reply With Quote
