Old 07-14-2017, 12:35 PM   #121
Hobotang's Avatar
Rated Cap: 83
Originally Posted by FuzzWantsABus View Post
Interesting! If you use it, let us know how it went.
Will do. Probably using a variation for the windows, 3M offers a UV stable 4000 as well. Not as strong but it'll do just fine
http://www.amelia-bartlett.com/the-skoolie/
Hobotang is offline   Reply With Quote
Old 12-28-2017, 04:20 PM   #122
Engine: 8.3 Cummins/MD3060
What about Tite Seal self adhesive waterproof flashing? Tough, sticks to everything, rubber based and waterproof. Thoughts?
Earp_C is offline   Reply With Quote
Old 12-28-2017, 07:34 PM   #123
Chassis: CE
Seems like an interesting option, Earp. I don't know how much it costs? Or how easy/hard it is to manipulate into covering only small areas? It may very well make a great sealant, if it's easy to cut into small pieces and apply that way instead of in large sheets.
FuzzWantsABus is offline   Reply With Quote
Old 12-28-2017, 08:26 PM   #124
It can be cut to size with a utility knife. Link to product below. On the fence about it. I may go the nylon fastener with sealant route. I dont want a failure after the fact.
http://www.cofair.com/window.aspx
Old 12-28-2017, 09:10 PM   #125
Originally Posted by Hobotang View Post
Spoke to a few folks in the marine/manufacturing industry, as well as a 3M rep. -- They all stand by this 5200 stuff. Bonds to everything permanently, even metal.
You may need to use their primer too:
When using 3M Marine Adhesive/Sealant Fast Cure 5200 with metals, it may be
necessary to prime the surface to achieve adequate adhesion and durability of the
bond. 3M Scotch-Weld Structural Adhesive Primer EC-1945 B/A may be used
for priming of most metals.
http://multimedia.3m.com/mws/media/5...-cure-5200.pdf
diannetea is offline   Reply With Quote
Old 01-21-2018, 08:36 AM   #126
Coachwork: Chevy Blue Bird
Engine: 3116 Cat
Originally Posted by Marvin View Post
Here are a few pics from this afternoon.
Can you explain to me your process here? My floors are maybe 65-70% covered in adhesive. I spent the day yesterday with the wire brush on the drill getting the adhesive off the wheel wells, but I feel like there has to be an easier way?
We saw on a thread there's really no point in spending all that time removing the adhesive when you're just gonna paint over it, but we were thinking we want a smooth as possible surface before priming. What are you painting with in these photos? Our floor has virtually no rust but that adhesive is really stuck on.
Thanks!
mapletwag is offline   Reply With Quote
Old 01-21-2018, 09:19 AM   #127
Chassis: Saf-T-Liner MVP ER
Thanks!
If there is no rust you can leave the adhesive. Prime over it. The primer will stick where it needs to and the whole lot will be covered anyway.
Steve Bracken
Build Thread
Old 01-21-2018, 02:09 PM   #128
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
If you do want the adhesive off a side grinder with a cup brush could be your best friend.
Old 01-21-2018, 02:28 PM   #129
So....I left the adhesive. Scrubbed the floor, rinsed twice and let it dry out completely. Put one coat of Rustoleum primer, plugged the bolt holes with plastic fasteners and sikaflex. Just finished with another coat of primer. Looks good and the primer has bonded well with the adhesive. We plan to plywood on top of metal floor and spray foam under the bus due to my 61 height and not wanted to split the bus in half for a roof raise. Ill probably put a thin layer of foam between the plywood and metal floor or vibration reduction and the fill in and gaps. Im happy with the results.
Old 01-21-2018, 03:41 PM   #130
You people belong in a tree. You're all nuts.
I was going to say Y'all are crazy but I can see your nuts.
I have a welder, sooooo...... I'll plug weld my holes if I ever get a bus.
If anyone uses the aluminum foil duct tape, you can spray automotive undercoat on the holes from underneath to seal water out. Flex Seal will work also.
ben2go is offline   Reply With Quote
