Old 05-01-2017, 09:06 PM   #11
Robin97396's Avatar
I don't know about the usefulness of using pennies either. I was just using that as one example of how someone had done it in the recent past.
On the other hand, so what if it takes three for four dollars worth of pennies to cover your floor. It's one of the smaller investments you'll make in your bus and well worth it to plug up those holes just in case you need to be water tight.
I could not tell you if copper (copper jacketed steel) pennies would corrode or not. I know they're magnetic pennies. If it's a fancy bus maybe you should use nickles?
Robin
Nobody's Business
Robin97396 is online now   Reply With Quote
Old 05-01-2017, 09:30 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by LincolnEcho View Post
you may not have it now but traveling in the northeast during winter months, you are gonna have yourself a rust bloom by end of spring at those holes if you don't do something on the underside to prevent it.
I'm thinking of painting the bottom of the floor as well to prevent the holes from rusting in the future.
I've already painted and undercoated most of my chassis. Used a bunch of RUst Reformer made by Rustoleum.
And I have zero plans of driving my 40 footer to the northeast ever. But my bus is gona be nearly invincible to rust by the time I'm done with it. I've ospho'd and primed the ENTIRE inside skeleton. Way past what 99% of builders do.
Old 05-01-2017, 09:32 PM   #13
Coachwork: IC
Chassis: CE300
Rated Cap: 32
steel wheat pennies from ww2 would do.
Old 05-01-2017, 09:43 PM   #14
Robin97396's Avatar
There was one time I received a Silver Certificate dollar while I was back east. I think I forgot and spent it.
I had lots of wheat pennies. The occasional Indian head nickel. I'm not compelled to put any change into the build of this bus. It's already taking bites out of my budget.
Robin
Nobody's Business
Old 05-01-2017, 09:45 PM   #15
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I still get silver certificates sometimes.
My buddy and I got a $5 one one night as change at a bar!
Old 05-01-2017, 10:07 PM   #16
Chassis: CE
Not done taking the rubber floor up yet but I've been thinking of this too. The plates from the school bus signs or the stop sign are perfect to punch out small circular hole "patch" material.
So, not to sound dumb, but what would you use to punch the holes out with? I've got all my interior skins sitting around, but it's all 16ga. Doesn't seem like it would be easy to punch or cut.
FuzzWantsABus is offline   Reply With Quote
Old 05-01-2017, 10:18 PM   #17
Robin97396's Avatar
I know a way that only cost a penny a hole. They've already been punched out. For any coach owners I'd suggest using quarters.
Robin
Nobody's Business
Old 05-01-2017, 10:39 PM   #18
Chassis: CE
LOL I do wonder about a galvanic reaction, though. I wonder if the epoxy/glue/whatever is enough of a barrier to prevent it?
Old 05-01-2017, 11:07 PM   #19
Robin97396's Avatar
I'd have a hard time saying if there'd be a reaction. Considering the pennies are largely steel electroplated with copper, I just don't know enough about metalurgy to venture a guess. I don't think copper is a reactive metal, and it's already on steel penny blanks.
Someone plugged holes in their floors with pennies a while back and I thought it was a cute and useful idea. They did use epoxy of some sort. I'd think pennies would be pretty good because the copper coating would keep the penny from rusting. Not that our pennies are best used to plug holes or anything. They do make cheap washers.
Robin
Nobody's Business
Old 05-01-2017, 11:35 PM   #20
Engine: T444E 3800 7.3L
Fuzz
I Corrosealed my floor today actually...
1. Yes, all that grinding was worth it and the more rust you can get off, the better. In regards to wiping it down with mineral spirits, it says on the bottle to not use mineral spirits. I went with Krud Kutter instead from Home Depot and it was perfect.
2. I haven't sealed the holes yet but now that the floor is done, I was planning on sealing it with Gorilla Construction Adhesive. Hope it's a good solution.
Gorilla 9 oz. Construction Adhesive-8010003 - The Home Depot
3. I grinded/cut out the caulking and will re-caulk it with the Gorilla stuff now that it has been Corrosealed. You want to do it after you Corroseal since you may cut the caulk off and find rust hidden under there. I basically mopped the floor with Corroseal and got every crack covered.
*Note - Trim out the edges first and then take a roller and do the rest of the floor. I did it the other way around and just started rolling and realized that it wasn't filling in the sides, so after it dried a bit, I went around the edge with a foam brush and got in the cracks. Very slippery!
The stuff comes out just like milk. Super thin. So just take and lather it on and go over it a few times to layer it.
Good luck!
Marvin is offline   Reply With Quote
