Old 05-03-2017, 03:29 PM   #41
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Robin97396 View Post
I don't actually have any pennies in my floor. However, I purposely leave dollar bills on the floor so I feel wealthy.
In all seriousness- any decent volume metal shop that does any punching will have buckets and buckets and hoppers full of round blanks.
finding them in thinner gauges may be harder, but if you have a metal fab shop nearby it couldn't hurt to call em up and ask.
Roll Your Own Build Thread
Old 05-03-2017, 03:57 PM   #42
Robin97396's Avatar
I think I'd probably weld any holes in the floor, but I haven't done my floor.
When I was a kid I often had a pocket full of those round blanks that come from the metal electrical boxes in new construction. Same size as quarters and used to work in some pop machines. Sorry, east coast it's soda machines.
Sometime I'll take pictures of my blue bus that I used blackjack roof repair tar to seal the holes in the floor. I didn't have to individually seal the thousands of screw holes, but there is a black tar worm dangling from each hole under the bus.
Robin
Nobody's Business
Old 05-03-2017, 04:28 PM   #43
Chassis: Gensis
I used pennies to cover the holes from excess moisture and critters. I used corroseal, then rustoleum, then used an epoxy glue then there is the penny. So if the coper gets through those 3 layers and makes contact I doubt it is enough contact to cause more problems than when the transportation department hosed the bogeys, gum, and puke out with a water hose.
Just wanted to add my non scientific view.
Second Star Skoolie Project
Crozz is offline   Reply With Quote
Old 05-03-2017, 04:38 PM   #44
Robin97396's Avatar
I'm betting your pennies are perfectly safe buried in your floor. In thirty years or so when you're redoing your floor you'll have something to look forward to.
Robin
Nobody's Business
Old 05-03-2017, 05:34 PM   #45
Chassis: CE
This thread is getting epic.
FuzzWantsABus is offline   Reply With Quote
Old 05-03-2017, 05:34 PM   #46
Chassis: CE
Ah-hah!! This is what I was hoping for.
Old 05-03-2017, 05:35 PM   #47
Chassis: CE
Also helpful! Thanks Crozz.
Old 05-03-2017, 06:21 PM   #48
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
I know you don't but you is both singular and plural.
Old 05-03-2017, 06:27 PM   #49
Brewerbob's Avatar
Only takes a scratch. Its a chemical reaction. Doesn't need critical mass or anything.
That said, this statement is also very true.
Old 05-03-2017, 06:54 PM   #50
Robin97396's Avatar
I was plural, but I've lost a lot of weight.
Robin
Nobody's Business
