Old 08-11-2018, 04:21 PM   #1
Foam Cabinet Build technique - anyone use?
I've read on multiple van sites and YouTube of van dwellers (full and part timers) building their cabinets using foam insulation board and making it rigid using paint/screen/paper or cloth covering and other similar techniques. There are some teardrops people have built using the same techniques. Has anyone built their cabinets/furniture this way and if so how durable is it? Attached is a pdf of one build technique I saved for reference.
Ultralight foam cabinet build technique.pdf
dgorila1 is offline   Reply With Quote
Old 08-11-2018, 06:01 PM   #2
brokedown's Avatar
Interesting stuff, I'm gonna ponder if I'd be able to use this in my build.
Old 08-11-2018, 06:12 PM   #3
It looks quite interesting. Saves lots of weight and you can build it easily with minimal tools and in a variety of shapes. Iíve just never seen it in person.
Old 08-11-2018, 10:59 PM   #4
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Great idea. I was thinking of using foam board for interior divider walls for sound absorbtion and weight saving.
Ted
Old 08-12-2018, 02:42 AM   #5
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
foam core
I have used foam core products 6mm (0.25") to 25mm (1.0") thick. The stuff I was working with has fiberglass strands mixed with closed cell foam, with a layer of chopper strand fiberglass on each side, about .5mm (0.020") thick.
strong and light. example..... 17mm thick, about 5/8" seemed to be about as strong as 5 layer plywood 13mm (0.5") thick, but was basically waterproof and weighed less than 6mm (0.25") plywood. The cost of this stuff was expensive, and I do not know about toxicity if burned. I think this get used for rebuilding boat decks amongst the more popular uses. cut and treat like plywood, wear particulate masks, I was using epoxy to glue edges together, no metal fasteners. neat stuff.... google "foam core fiberglass composite" lots and lots of stuff out there.
william
Old 08-12-2018, 09:39 AM   #6
I watched a shower stall with a foam bench built on this old house.
