Old 09-30-2008, 10:03 PM   #1
GoneCamping's Avatar
Re: Fridge Vent!
You'll need 2 holes... One in the side behind the lower section for air inlet AND access to the business section of the unit... Another one either in the side near the roof, or in the roof. Both holes have special covers that you can buy on ebay...
Covers for the side are THESE
The roof vent will look something like THIS
Remember, the RV style refride uses heat to make things cold (don't ask me to explain how it works), and it'll need adequate ventilation or it will not do it's job.
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 09-30-2008, 10:04 PM   #2
Re: Fridge Vent!
As an addendum to the above post, you could try going to the Dometic and/or Norcold website and see if they have some installation instuctions, they may not have your specific unit but they all basically go in the same way!
*Cliff*
help with fridge vent lornaschinske Heating, Cooling and Appliances 5 06-11-2017 10:56 PM
Installing A Fridge lornaschinske Heating, Cooling and Appliances 3 05-16-2011 06:41 PM
What is this vent......... Funkpirate Conversion General Discussions 5 04-15-2010 09:46 PM
Propane Fridge ezbme Everything Else | General Skoolie Discussions 5 05-08-2009 09:17 AM
dorm fridge westport_wayne Heating, Cooling and Appliances 7 04-09-2006 09:24 AM
