Old 03-17-2010, 07:13 AM   #1
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Furring Strips
I didn't see a tutorial on it, and while it seems simple enough I figured it would be good to share some ways on how to install them. Do you guys install your insulation first and then screw the strips into the insulation? Or do you guys first put the strips into the metal wall and if so do you use liquid nails to get them on or sheet metal screws? I figured screwing them into the wall would be best, but I am worried about the metal screws coming out the other side of the bus. Please share your experiences.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 03-19-2010, 06:37 PM   #2
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Re: Furring Strips
I figure a good way is to pre-drill holes like you said because that metal is not easy to penetrate, and then line up the wood and secure it in with 1.5" screws. I like the idea of not using and adhesive to make the insulation stick. It makes sense that if you cut it right that you can make it fit nice and snug, I'm sure putting duct tape on the edges of the insulation and sticking it to the strips wouldn't hurt either.
Old 03-19-2010, 09:15 PM   #3
the_experience03's Avatar
Re: Furring Strips
I didn't do anything with my walls, but when I laid them out on my floor I simply designed a grid that would work easily given my obstacles and such without getting too much space between the strips (no larger than 16 inch centers). My strips are attached with liquid nails, but I had to use decent screws and the predrilling technique to hold them in place while the adhesive set up.
Cutting that foam is a pain. There are two methods I've used with success. One is to use a higher tooth count circular saw blade and install it backwards in the saw. This works well, but it's tough to get a straight line so I've also built a rig on a bench that used a piece of wire wrapped around some bolts so I could tension it and then energized the affair with my welder making a hot wire cutter. It's obviously a lot more difficult to engineer than a backwards saw blade, but it sure cuts that foam.
Old 03-20-2010, 09:09 AM   #4
Re: Furring Strips
The difference might be the polystyrene. My insulation is the lower R-value styrofoam stuff as I was just going for sound deadening and I got a super deal on it.
Old 03-07-2016, 09:34 AM   #5
cheryl_ann44's Avatar
Chassis: International 3800 chassis
Engine: T444e
I am very interested in what you decide re: screws vs. liquid nails because I do not want screws coming through to the outside either since I am planning on taking down the inside sheet metal to insulate
Please let me know
cheryl_ann44 is offline   Reply With Quote
Old 03-07-2016, 10:18 AM   #6
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Liquid nails is ok for some applications, but in a wood to metal high humidity application it probably isn't going to hold up too well. Add in the vibration of a bus and travel and I much prefer mechanical fasteners;
Old 03-07-2016, 11:20 AM   #7
Skoolydoo's Avatar
Rated Cap: 2+1
There is a saying in woodworking and carpentry (measure twice cut once) well that can be applied to drilling and using screws...I myself have built many projects using self
Tapping screws, they drill and secure at the same time..just be sure you have the right screw size and length for the appreciation.
Always be sure to figure on counter sinking your screws so that the outer layer of your project doesn't end up with bumps where your screws are.
Any Type of Glue will fail over time by it self.
I myself do not much care for liguid nails, for some reason it never worked that well for me..
If you can find or have near you some place that builds metal building, they have a product that they put in some seams that will hold anything..comes in a tube like
Liquid nails( don't get it on you as it has to wear off) lol ask me how I found that out.
Good luck and I hope this info will help some..
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
Skoolydoo is offline   Reply With Quote
Old 03-07-2016, 12:45 PM   #8
Chassis: B3800 Short bus
Liquid nails
You're probably thinking of PL Premium. That stuff is great! I started using Liquid Nails first and was later recommended PL Premium by a friend of mine who works in the construction/carpentry trade. It is far superior.
Wear gloves if you have them, though. As was mentioned it is impossible to get off of the skin. It has to dry and fall off with the dead skin cells.
Old 03-07-2016, 03:03 PM   #9
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I did a bubba job on my mailbox using liquid nails. I couldn't get a screw into the 3/6" steel I'd made my mount out of. I used liquid nails liberally. Plastic to steel. It fell off a month or two later and I got out my drill and bolted it on.
Will two 12v LED light strips run off the same source at ful chev49 Conversion Tutorials and How-to's 1 07-10-2012 11:28 AM
attaching firring strips to ceiling robnz1 Conversion General Discussions 0 09-11-2010 04:25 PM
