Re: Glass
Actually, it should be easier on a bus. Those frames are meant to be taken apart. But any time you don't have to worry about cutting the Tint to proper size without messing up the window caulking/rubber is a good thing. Take the window apart, put the tint on, trim to proper, put it back together. Only problem would be if you manage to damage the tint, you have to take the window apart to redo it.
