Old 05-04-2011, 09:48 AM   #1
Chassis: Thomas
Engine: 5.39 Diesel
going off grid > electrical
We have purchased a bus conversion. The current set up requires the bus be plugged in to run any outlets, with a few (water pump & one set of lights) on DC.
There is a converter with AC and DC panel, battery bank, and power plug. The house batteries are not connected to the engine's alternator. Should they be?
Is it better to replace the converter with an inverter/charger, which would mean installing an AC and DC panel?
OR
Is it okay to just install an inverter for the AC outlets?
Is there concern that a converter does not properly charge house batteries? If going the plan to just add an inverter, should I consider getting a multi-stage battery charger?
Do I need to choose a pure sine inverter?
In an effort to live off grid, we will use a generator to charge the batteries as needed.
Should we also add a surge protector?
Thanks
writejill is offline   Reply With Quote
Off-grid traveling family dreams lgonzalez Skoolie Conversion Projects 41 01-10-2015 02:27 PM
Solar vs. Grid usage inkblots84 Conversion General Discussions 0 02-24-2013 04:31 AM
School bus becomes off-grid, transformable, tiny home bansil Everything Else | General Skoolie Discussions 8 01-07-2013 12:20 PM
Planning a self-sufficient off-grid power system tomas_maly Electrical, Charging and Solar 10 07-30-2012 09:01 AM
Off Grid Water lornaschinske Conversion General Discussions 32 05-30-2010 07:21 PM
