Old 06-22-2015, 04:24 PM   #91
Seroflorus's Avatar
Engine: Cummins 5.9; MT643
Rated Cap: (was) 44; (now) 2
maybe you can get more info but i can say pretty certainly you'll want a distribution panel (like in a house, sorta)
possibly like this: http://www.amazon.com/Progressive-Dy.../dp/B002XRU6FM
so you can go AC or DC (in case you have solar aspirations or decide to spring for the genny). If you go with DC power options, you'll want an pure sine wave inverter to run your AC power sensitive goodies like computer electronics but you can use a modified sine wave inverter (lower cost) for your 'not very complex' appliances...though with all the electronic gizmos thrown gratuitously into everything, I think I'll just go with one pure sine wave inverter for the whole show. Go here to find out more than you really wanted to know about inverters and batteries....http://www.batterystuff.com/inverters/
Seroflorus is offline   Reply With Quote
Old 06-25-2015, 08:32 AM   #92
This thread got a little muddy for me, so excuse me if my question has been covered, but as I am not as electrically inclined as some, I was wondering what would be the best way for me to go. I want to use a total solar set up (possibly with the potential of hooking up, but I plan on doing as much boondocking as possible). The only things I need to power would be a small fridge (still doing some research, but I was hoping 5-6 cubic feet, with a separate freezer), some LED lights (8-12), and a charger for a phone, and laptop. I was planning on using propane cook top, and heater, but if adding it to a solar set up would be more efficient, I am ok with that. If someone could just give me some direction, without getting into too many details (I am still learning, so bare with me), and tell me what kind of panels, charge controller, inverter, and batteries (and how many of each), I will need, I would appreciate it..
Trying to figure out my budget, and where I want to spend money, and save money.
kvanydke287 is offline   Reply With Quote
Old 06-25-2015, 09:26 AM   #93
Seroflorus's Avatar
google this: "skoolie.net solar"
Old 06-25-2015, 11:10 AM   #94
Engine: 190hp 5.9 Cummins
I agree.
This has been covered over and over again.
Old 06-25-2015, 11:16 AM   #95
Originally Posted by nat_ster View Post
I agree.
http://www.skoolie.net/forums/f13/so...zing-7955.html
If that is what I was supposed to be looking for, that is over kill for my situation.. I do not need to power as much as they do. I have tried searching, and have yet to find anyone that is powering exactly what I am.
Thanks for the info, guess I'll just ask someone in person..
Old 06-25-2015, 11:38 AM   #96
The member named jazty has a nice smaller setup. This is his thread.
http://www.skoolie.net/forums/f27/ar...t-8870-15.html
I run a 12 inch by 12 inch 7 watt solar panel and a 8D battery to run now 8 MR16 3 watt lights for 12 hours a day in my shed.
There is info within the build threads.
Old 06-25-2015, 11:44 AM   #97
Thank you Nat. I am still new to the forum world, so my search always yields a lot of results, and sometimes I don't have patience to read through all of them to find what I need. Call it laziness, but I will get the hang of it one day!
Old 06-25-2015, 12:03 PM   #98
Chassis: Blue Bird
Engine: ISC 8.3
The search may yield better results if you modify it slightly. Search for "site:skoolie.net solar" instead. For the Google engine, the "site:" keyword/instruction tells it to search only the given web site/domain.
Basically, what you'd be looking to learn about from other threads, is how to estimate your daily electric loads and add them up to size the battery bank, solar panel array, and charge controller. Watch for how they figure the current and voltage for each load, multiply them together and also multiply by hours of use per day to come up with kilowatt-hours (kWh). You add up the kWh and there's the load your battery needs to supply. Battery banks are usually rated in amp-hours (Ah) though, so divide the volts back out of kWh and you have Ah. If any of the loads are 120 V, ie running through an inverter, multiply their kWh by about 1.2 to account for the conversion loss in the inverter. Also watch for people's comments about over-sizing of the battery bank according to the battery chemistry, and about both the battery and the solar being over-sized to get you through cloudy or rainy days.
That's not much specific, concrete help.. but hopefully it gives you a little guide to what kinds of concepts you're skimming/searching for.
Old 06-25-2015, 04:53 PM   #99
Also read around on Handy Bob Solar. Dense material and an opinionated author, but the information is solid and very practically-oriented. There's also a good book called Managing 12 Volts, by Harold Barre.
Polarweasel is offline   Reply With Quote
Old 06-25-2015, 05:33 PM   #100
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
Okay I don't know as much as I'd like to about this - I also want to add solar and a bank of batteries. But here's what I came across the other day... And I don't know if these are in every town but here it is.
I found a battery recycling, refurbishing, and surplus sales place that had the AGM Gel Batteries for $110 ea... I bought two for my bus. The same style (...and again I don't know batteries) of battery at West Marine is $700...
THAT... got my attention. So I bought two they were new on pallets and the old man seemed real knowledgeable and told me these will last 4x longer and put out twice the power as wet cell batteries...
So now I'm in the affordability range of going solar~
Thomas
Safety Liner MVP
USMCRockinRV is offline   Reply With Quote
Starting my Research.. finding more questions than answers admiller Conversion General Discussions 0 09-15-2014 11:36 AM
electrical questions proconsul100 Electrical, Charging and Solar 5 03-31-2014 01:28 PM
Electrical Questions iowacamper Conversion Tutorials and How-to's 32 11-15-2013 04:09 PM
Electrical questions BUSBOZO Electrical, Charging and Solar 10 02-09-2010 10:20 PM
So many electrical questions Dolores Conversion Tutorials and How-to's 4 07-25-2008 08:48 AM
