Re: Help Fixing Turn Signals
There should be a fuse for the turn signals, you might also check the flasher, they only cost a couple of bucks and easy enough to replace...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
