You can do it all.
1. Tires. You can buy a bus for the same money with nearly new tires vs 10 yr old tires. Look at the side walls. Get the codes so you can tell how old the tires are. Nice deep tread can be deiciving. Get down on the ground and look at the inner side if the tires for cuts etc. While you are under there look at the exhaust and look for rust especially under the wheel wells. Crawl to the right side of the tranny and read the tag to see what tranny it is.
Others will add to this hopefully. We really need a stick for this type question.
