Old 02-03-2017, 01:20 PM   #11
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
Look at my album. Just one way of doing things. Lots of wood to screw to.
my build pics
Old 02-03-2017, 06:49 PM   #12
And THANK YOU!! For all the helpful input.
Roundbed is offline   Reply With Quote
Old 02-03-2017, 06:58 PM   #13
Coachwork: IC
Chassis: CE300
Rated Cap: 32
If one can't afford spray foam, foam board is a good alternative.
Spray foam is king, for sure though.
Roll Your Own Build Thread
Old 02-04-2017, 07:42 PM   #14
Thank you for y'all's input!
To Superdave,
In your album, it looks like you didn't build any wooden frame work for the walls, and just used the metal framework that was there?
Also I see sprayfoam, then polypro, and then what did you use for a moisture barrier and your final outer wall?
I am also wondering what do you/did you secure your outer wall to? The steel bus frame doesn't seem like something I can drill into (?).
And finally,
I watched a video that said to put the metal walls back in as they serve a structural purpose to the bus, but it seems like many people simply replace them.
What is your (or anybody's!) suggestion?
Thanks guys!
I am eager to get started.
Old 02-04-2017, 07:45 PM   #15
I keep looking at all my roof rivets with utter dread.... Everywhere they're placed is a thumb's width apart
Old 02-04-2017, 08:27 PM   #16
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I've got video to post of rivet removal.
Will have the vid up tomorrow evening.
Old 02-04-2017, 08:29 PM   #17
Coachwork: IC
Chassis: CE300
Rated Cap: 32
To Superdave,
And finally,
Thanks guys!
You don't have to put the tin can interior back on. It won't really work tryning to do so, anyhow. Would be a huge pita for nothing.
THe sky won't fall if you pull it out and put in whatever you like.
Old 02-04-2017, 08:42 PM   #18
Yeah. The ribs that support the roof/walls are practically a roll cage anyway. That sheet metal seems pretty minimal in comparison.
lucasd is offline   Reply With Quote
Old 02-04-2017, 09:00 PM   #19
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Its often nothing more than perforated 18 or 20 gauge.
Old 04-29-2017, 05:29 PM   #20
Has anyone used the foam from the seats for wall insulation? I am considering it. We live in Arkansas and the winter is short and we will have a woodstove. In the past I have had buses in the winter in Canada and California and never insulated, but did have a woodstove and lots of blankets at night!
Wild Rising is offline   Reply With Quote
ceiling insulation, insulation, rust paint, vapour barrier, wall insulation
