Old 04-29-2017, 06:04 PM   #21
Robin97396's Avatar
I'd hate to think about how much water the foam could hold. Foam holds water, and water makes mold. That's why we specifically use closed cell foam to insulate, iether in rigid foam or spray foam.
At first I thought you were talking about putting it on the interior surface, like so you don't bump your head.
Robin
Nobody's Business
Robin97396 is online now   Reply With Quote
Old 04-29-2017, 06:23 PM   #22
spenceronehalf's Avatar
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
If I used the foam from the seats I'd be adding ... A LOT OF MICE TO THE BUS
spenceronehalf is offline   Reply With Quote
Old 04-29-2017, 06:40 PM   #23
Robin97396's Avatar
If I was stuck in Alaska in an uninsulated bus during the winter, you can bet I'd MacGyver that foam right up on the ceiling. Mice and all.
Robin
Nobody's Business
ceiling insulation, insulation, rust paint, vapour barrier, wall insulation
