Old 06-29-2018, 11:49 AM   #1
Help! Trying to figure out intake modification
Ok.... I have a 2003 Bluebird All American Pusher. This black cover is what I think is the intake for the engine. There is only one of these on the passenger's side. We really want to put out bed up there and move this. Has anyone modified this or moved it? How would you do it? What problems do you for see? Thanks everyone for the help!
katiearnold is offline   Reply With Quote
Old 06-29-2018, 12:02 PM   #2
Coachwork: None yet
What's on the outside of the bus that connects to that piece? I assume a louvered panel? What's behind it? There may be a large air filter, or it could just be an intake plenum that sends air to the engine compartment. Taking a look inside will tell you a lot more about what your options are at this point.
cycle61 is offline   Reply With Quote
Old 06-29-2018, 12:11 PM   #3
Show a pic of what's inside the engine bay under that housing. I suspect there is a filter and an intake tube running under it to the intake manifold. You would need to find another place for that filter that will draw clean fresh air and then plumb the intake tube to the manifold.
Old 07-25-2018, 01:42 AM   #4
Chassis: Bluebird All American RE
Engine: Cummins
Any progress on this? Just got my 2000 Bluebird All American and was wondering the same thing. I don't have a pic to post, but indeed under there is just the intake. It is not vented to the outside that I can see, other than by the engine compartment doors.
If one were to re-locate the intake further down into the engine compartment, does that affect performance at all? Does that intake need to be higher than the engine in order to draw air?
ekyoung is offline   Reply With Quote
Old 03-12-2019, 09:37 AM   #5
Engine: CAT
We are battling the same issue. Here is a pic of what's under the black cover. It's a weird setup, the filter is below the metal plenum and the air intakes on the outside of the bus are above the plenum.
HyggeBus is offline   Reply With Quote
