11-11-2018, 10:46 PM
Help:what tool I need
Hi, everyone
I am gonna buy my schoolie next week, but I have no idea what kind of tools I need to convert it?
Please help me a list about it..
Thank u...
11-12-2018, 01:23 AM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
You will need them all lol
So a quick list of what I think you need...
Basic tools - screw drivers, hammer, wrenches, socket set, channel locks, and vise grips.
Power tools - 4" angle grinder ( metal cut off discs and flap disc), reciprocating saw (or a hack saw and muscle power) drill (corded), drill (cordless)
Depending on how detailed your conversion is, the tool list could be almost limitless.
Are you going to weld? Wood working? Painting?
All require tools. Some you can rent or borrow if they are flr specialty applications, or one offs...
Originally Posted by liang2013
Hi, everyone
Thank u...
11-12-2018, 03:12 PM
Rated Cap: 35 kids
tools needed...
Money, motivation, Money, cordless drill, skill saw, Money, Hammer, grinder, Money, Patience, a vehicle to haul lumber,etc, creativity, You Tube access, first aid kit, and Money....
11-12-2018, 03:18 PM
I sorta just buy the tools as I go. I already had a good bit of tools to begin with.
Angle grinder and impact driver are two important ones.
11-12-2018, 03:44 PM
Chassis: IH
The first thing you absolutely need is a good fire extinguisher! This is like a parachute in that you hope you never need it, but if you do, nothing else will really do the job and you need it *Right Now*. The bus may come equipped with one, or at least a bracket for it. Also get some reflective triangles if the bus lacks them. They might come equipped if the seller didn't cannibalize them. A first aid kit would be wise and third down on my list of required items. Again, all these items are usually on active school buses but the seller may strip them before sale.
Basic hand tools will be in order. Most of the other suggestions are good so I won't repeat those. Once you get your bus, procure a couple extra fuel filters for it and keep them on hand. Learn how to change them yourself, it's one of the most frequent bits of maintenance a diesel requires.
11-13-2018, 03:07 PM
That is really helpful. And yes, I want do wood working too..
Thank u.
11-13-2018, 03:10 PM
thank u, i don't have pick up vehicle,I plan use school bus to haul lumber,is that ok?
11-13-2018, 03:13 PM
That is great safe and details things. I will never imagine that by myself.
Thank u.
11-13-2018, 07:23 PM
My cordless drill gets used more than any other tool I have!
Make sure you have multiple batteries
11-17-2018, 03:51 PM
Owning the needed tools is one thing however you also need the knowledge, skill and ability to use them properly and safely.
The first thought that came to my mind when reading your original question was this:
Given the basics of your original tool question are you sure you have the time, skills and ability to complete this HUGE PROJECT that requires many varying types of construction needed to successfully complete a Skoolie conversion?
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
11-18-2018, 01:01 PM
Engine: International
Rated Cap: 7 Window 20 Passengers
Tools
You will need several drills, cordless & corded heavy duty. If taking seats out & you don't have a helper or a pit to work under the bus you'll need a small & large corded grinder, this was the hardest part of my bus so far. Use good safety glassed & wear genes not shorts when grinding & no flammables around what your grinding. As others have said, Money is the key & a close by Home Depot or Lowe's you will visit them a lot... You should have plenty of very good drill bits & at least three of the each ones you use a lot. Plan to do most things twice, this is a conversion & there just aren't many guides for it. Every bus is different so layouts, plans everything changes as you go along. If you've planned 4 months add 4 more.
Plan to have several screw drivers, regular & metric sockets & several short to long extensions. Plan to learn a lot, more than you ever wanted to know about a bus & then some. Do as much work in the Fall, Winter & early Spring out of the main heat months.
Donn' dismantle it, take it apart or destroy it before you know you will never need it again! Never be embarrassed to ask for help or advice, especially when it comes to Electrical or Air Conditioning. NO BODY KNOWS IT ALL, NOBODY!
Finally keep a good First Aid Kit nearby, have kids or helpers, go over safety first, second & third. Plan on a true Adventure & when you get really frustrated, stop, walk away, do some soul searching, deep thinking then start right back in.
Have Fun!
I've attached a few pics of the BoogieBus Started in May 17 still a work in Progress. Here is the FaceBook Page associated with it: https://www.facebook.com/MrBoogiesBu...dmin_todo_tour
11-18-2018, 01:17 PM
THIS!
I am reminded of a saying when I was an apprentice electrician.
Here it is, " Anybody can do a job with the right tools, a tradesman can do that job with no tools. "
We always had a good laugh over that and yes there are times you need to improvise.
11-20-2018, 10:43 PM
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Just make sure to leave the guard and handle on the grinder. Wear safety glasses AND a face shield AND gloves when using the grinder. They are emotionless and unforgiving.
Nick
11-25-2018, 08:45 AM
Chassis: International 3000
Engine: DT-466
Rated Cap: 64 passenger
Other than that. I’d start with an angle grinder a flat shovel and a crowbar. And a harbor freight gift card haha
