Old 04-07-2012, 04:25 PM   #1
holes from bus seats
how do you recommend to fill the holes left from the bus seats. i dont have a weilder and i cant get one either
On the trail to Eagle
thewallfan is offline   Reply With Quote
Old 04-07-2012, 08:30 PM   #2
TygerCub's Avatar
Engine: Detroit
Re: holes from bus seats
Aluminum tape worked for my first bus. Easy to install and cheap.
Old 04-07-2012, 09:02 PM   #3
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
i sprayed rust reformer liberally into the holes to prevent and rusting to spread, then i used black rtv silicone and aluminum tape. i squirted a bunch of silicone through the hole, then used a putty knife to scrape the hole level, and apply aluminum tape over it then.
hordechick is offline   Reply With Quote
Old 04-08-2012, 02:33 AM   #4
cheap and effective way would be using the black windshield rubber calk from the automotive refinishing store that goes in your calking gun. once it is in, it won't come out.
Old 04-09-2012, 05:33 PM   #5
so something like this:
http://www.ebay.com/itm/Windshield-back ... c9&vxp=mtr
Old 04-13-2012, 09:53 AM   #6
maybe...i use the stuff to install the windshields.... it is black and available at the automotive paint stores...
Old 07-02-2012, 11:48 PM   #7
eyedeal.ink's Avatar
We're using rustoleum then 3/16 x 1/8" aluminum pop rivets. Finally, we'll cover the entire surface to the top of the chair rails with a couple coats of elastomeric roof paint (water/bug tight).
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 04-21-2015, 04:36 PM   #8
thecrabshomestead's Avatar
Coachwork: Genesis International
Hole fillers
Did any of yalls ideas on filling your holes work? Did it prevent the rust from spreading from the bottom of the bus? Considering the aluminum tape and aluminum rivots..just wasn't sure what the results were. Thanks!
Mocrab
https://thecrabshomestead.wordpress.com/category/tiny-house-skoolie/
thecrabshomestead is offline   Reply With Quote
Old 04-21-2015, 04:41 PM   #9
Engine: 190hp 5.9 Cummins
No aluminum.
Read some build threads. All the info has been covered over and over and over and over again.
Patching holes in the floor swhite832 Conversion General Discussions 9 04-22-2015 10:07 AM
Necessary to patch floor bolt holes? mtunderwood Conversion General Discussions 10 12-10-2014 12:14 PM
Punching holes in my roof - best way to seal em? Lightfoot Conversion General Discussions 14 09-03-2014 01:50 AM
How did you Patch Light Holes?? usmcbay Conversion General Discussions 9 03-30-2012 04:42 PM
Sealing holes in floor firemanbud343 Conversion Tutorials and How-to's 10 09-27-2009 10:00 PM
