Old 10-13-2016, 07:07 PM   #11
Chassis: Thomas
Engine: Cat 3126 7.2 / Allison AT545
Rated Cap: 77 Passenger
I am installing mine indoors!!! have read tons on vent/no vent. I have not decided whether I will vent. it would be easy right now but MANY say there is no need to.
PoolRoom is offline   Reply With Quote
Old 10-13-2016, 09:14 PM   #12
dredman's Avatar
one year full timing with the the Ecotemp, and a Shurflow, best purchases I have made to date.
Before you start panicking about ventilation, do you really expect to be cooking your water for more than 20 minutes? Cooking meals with propane causes 30x as much CO, and burns more propane but people still panic? If you are using a tank-heater, you should vent, otherwise you are wasting your energy on fear.
My 3 Year Adventure
dredman is offline   Reply With Quote
Old 10-13-2016, 09:19 PM   #13
Chassis: Thomas
Thank You dredman!!
That was my feelings as well. My Eccotemp will be for the shower ONLY!
Old 10-14-2016, 05:37 AM   #14
Year: 1983
Engine: 350
Rated Cap: 20 something
I have an eccotemp N40 I picked up for a song on craigslist a few years ago and love it. i can fill my wood fired hot tub in one fill at whatever temp i want and only need to use wood to maintain the temp. I plan on getting a L5 for my bus.
pannebreaux is offline   Reply With Quote
Old 10-18-2016, 12:17 AM   #15
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
Mass Heat
I have a L5 as well. I have not fired it up yet, as I am still installing plumbing. I am however, (against many people's advice) going to run it through a 20-plate heat exchanger that is plumbed into my underseat heater (I kept one of them). I don't plan to normally run water through it, but I like the idea of bringing an inflatable pool or something for an impromptu hot tub. That way I can heat tons of water by using my engine heat and L5 at the same time. Normally I will only have my sink and outside shower, so I will bypass the heat exchanger.
SDR76 is offline   Reply With Quote
