Old 04-01-2005, 09:23 AM   #11
skoolie_grease's Avatar
wow, thanks lapeer20m!
it is a diesel and the link you provided is super.
when you say tighten the nut to 'increase the rpms', that is essentially the governor then? they've just limited the rpms by loosening the bolt?
would this change the rpms at which the tranny changes gears? sometimes i think it goes a little high... or at least, it's so loud that it would bother the pedestrians on the street. i don't want to stress or damage the engine, but if it wouldn't hurt to lower the rpm at which it changes gears, that would be nice for everyone i pass.
thanks again for the link and info!
sKOOLie: 1992 International 7.3L Diesel Short Bus
...:: http://www.skoolie.info ..::.. http://www.goodgrease.com ::...
skoolie_grease is offline   Reply With Quote
Old 04-01-2005, 07:33 PM   #12
lapeer20m's Avatar
the little springs that get tightened are part of the govenor. The job of the governor is to do exactly that: govern engine rpm's.
I am not a diesel mechanic, but i've been told that skoolie engines are usually set very low when it comes to rpm's compared to the same engine used in other vehicles.
IT's not necessarily advisable to increase the speed of your engine. The faster an engine turns, the shorter it's life span will be. That's an important thing to remember.
IF you want to increase the rpm's of your engine, you should first find out what the max allowed rpm or redline is for that engine. You never want your engine to go faster than that! The engine probably won't last very long if the bus were driven for long periods of time with the engine at max rpm either. You'll need a tachometer to know how fast the engine is turning.
basically, what i'm trying to say is that if you don't alter the engine rpm, the motor will almost certianly last longer. How much will you shorten engine life by increasing the rpm's???? that's a mystery.
Old 04-17-2005, 06:40 AM   #13
well your right we got off the beaten path for awhile there but back to goveners i've got a 84 gmc with a 454 and like i said in the beginning i dont want to go 70 down the highway im ok with 55 to 60 but this thing would'nt let me get passed 52 or53 so after talking to a few people i went down and bought a new carborator (elderbrock) and i installed it. it bolted right up and ran great. i headed down the road and wow what a change 70 mph no problom now i did what was suggested and put in a tach. i just did;nt like the feeling of no extra power when i needed it. but you also have to watch it cause like was metioned in here allready you dont want to push your bus to the red line either. alot from what i understand is in the rear end of these things and if you really want good speeds without hurting you bus make it all work together. http://home.bellsouth.net/p/PWP-jrwon
heath692 is offline   Reply With Quote
Old 04-18-2005, 10:28 PM   #14
governors
I read all of the posts regarding governors and was particularly interested in the comments on diesels. My son and I are both working on skoolies. I'm sure the neighbors hate seeing two old buses. He has a Ward with a 9 liter International. And . . .it isn't too quick. Do some of these buses have SPEED governors instead of RPM governors? If so, how do you change a speed governor (if there is such a thing). He is turning his bus into one of those huge pick-up trucks by cutting away the back bodywork. He will lose a lot of weight without the back half of the bus. Could he find a higher geared differential for more speed? Coments?
Herb in Utah
Flat-nose Blue Bird[/b]
Skoolie BOBB is offline   Reply With Quote
Old 02-16-2006, 08:01 PM   #15
If it's a computer controlled diesel, a shop that services that engine can program the computer to not limit your top speed or RPMs.
We had that done on our Thomas/Cat.
A two barreled gasser can get a new 4 barrel carb. Make sure it's done correctly! A poor carb job caused us daily headaches on an old gas skoolie during a cross country trip.
Carbs are pretty inneficient machines. If you are comfortable working on carbs, Eagle-research.com sells a Carburator Enhancer Manual by George Wiseman for $24.00 that should get you smoother power and more MPGs with a weekend worth of tinkering.
Check your rear end gear ratio. Low gearing means slow speed. Generally school systems that don't do much highway traveling use low rear gearing. Private companies that contract for schools tend to use higher rear gears. Changing the gearing can be a pain in the rear!
dravo is offline   Reply With Quote
Old 02-16-2006, 08:23 PM   #16
the_experience03's Avatar
This thread has been interesting for me to read as I was thinking about the governor on my bus as I was bringing it home. It does 63 mph just fine and held onto 55 even on the big curvy hills. In fact, I would venture to say it out accelerates my 22re powered Toyota pick up and has about the same top end Not too bad for a "gutless" 6.6 IMHO. Still, it's geared somewhat higher than it appears others have because at 63 mph it's barely turning 2600 RPM. I haven't had much of a chance to really dig into that motor to look at it (this is my first diesel) and get a feel for everything and finding information on the brazilian motors is harder than finding parts for them. 60 mph is a fine cruising speed for me, but it would be nice to have that little extra on tap if need be.
So here it is....anyone know what injector pump Ford used on the 6.6/7.8? I know several manufacturers used interchangable parts like compressors, injector pumps, etc. If anyone has a clue, I'd love to hear it.
Old 02-17-2006, 09:47 PM   #17
lapeer20m's Avatar
my 6.6 had the bosh inline injector pump..perfect for running veggie oil. You can look at the pump if you open the hood (conventional dog nosed bus?) The IP is on the passenger side and clearly visible...it's the thing that has 6 steel lines running to the top of the motor.
For parts, you can search for a commerical ford truck dealer...they have parts, but they are not cheap.
Old 02-17-2006, 09:56 PM   #18
lapeer20m's Avatar
Turned up the govenor on Phillbus' skoolie today. WE only drove a couple miles, but looks like she'll drive about 65 now instead of 57.
That "10 minute" project took most of the morning and half the afternoon, but we got er done!
Did i ever mention how much I love working on snub-nosed skoolies? (that's a joke, although not a very funny one)
Old 02-18-2006, 12:09 AM   #19
Is turning up that pump just a matter of adjusting the internal spring or what? The stealership in town can get parts, but my budget is for stuff like a power invertor to run a playstation, not for mechanical parts. Like I said...I haven't really looked at it all that well because it's too dang cold right now. Any idea what the mechanical redline is on the 6.6? For being a "dog" of a motor, I'm rather impressed with it, but if there's more, I'll take it
Oh and yes...the bus is a conventional with a convenient (albeit heavy) flip front as opposed to the standard hood on the gasser B700's I've seen....ewwww.....
Old 02-18-2006, 01:42 AM   #20
phillbus914's Avatar
Ohh comeon, wasn't it nice to not have to go outside in the cold to open the hood? and uhhh... well yeah I guess thats about the only positive thing on working on a snub-nose. But hey it sure runs a lot faster now.
My Old Bus :(
new to buses chev49 Everything Else | General Skoolie Discussions 1 07-13-2012 11:45 AM
Chevrolet/GMC ignition retarder/govenor Kirbystud Conversion General Discussions 12 07-26-2009 01:15 PM
Party Buses (In Buses In The News) lapeer20m Everything Else | General Skoolie Discussions 4 07-03-2008 02:43 PM
Buses buses, ya wanna know about buses ??? frank-id Everything Else | General Skoolie Discussions 0 10-19-2006 11:42 PM
Crown ??? Crown buses??? The best of all the school buses frank-id Conversion General Discussions 1 03-05-2006 03:30 PM
