Old 02-24-2006, 10:04 AM   #31
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
at least I'll get more than 62 mph.
Roasting8 is offline   Reply With Quote
Old 02-24-2006, 05:29 PM   #32
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Yeah, but aren't you worried about upsetting the time/space continuum!?! PEOPLES LIVES ARE AT STAKE HERE! DON'T TOUCH ANYTHING 'TIL I GET UP WITH CARL SAGAN AND STEPHEN HAWKING!!! (Whew, that was close!)
Griff is offline   Reply With Quote
Old 02-25-2006, 04:49 AM   #33
Griff's Avatar
Year: 1982
Chassis: IH S1723
Originally Posted by Overand
Good luck getting together with Carl Sagan, he has, uh, transcended the physical plane.
Yeah, I know. . . did I not mention the time/space continuum?
Old 12-07-2006, 09:13 AM   #34
Elliot Naess's Avatar
Engine: 5,9 Cummins
Well guys, I can report that "I cut the wrong wire" on my first bus and the engine did indeed blow up. That was the 1981 International with a MV404 and a 7-something rear end. And the tachometer did not work. I took it up 65 MPH and bent the valves. One of the push rods looks like a boomerang. So DO be careful with RPMs!
(voice of Mrs. Roddenberry: "Warning. Warp core breach in 20 seconds.")
Elliot
Old 10-30-2007, 09:48 AM   #35
DizzyIzzy's Avatar
Chassis: Chevorlet AT545 Allison auto
Engine: 8.2 litter Detriot Deisel
Send a message via AIM to DizzyIzzy Send a message via MSN to DizzyIzzy Send a message via Yahoo to DizzyIzzy
Re: How to adjust a buses govenor
I personally believe that they govern these buses for 2 reason.
1. For safe operation of the bus motor.
2. For the safety of the passengers.
Ahhh so there is a reason they only go so fast. But there are things you can do to help with some extra speed. Change the rear end. Then your RPM's stay the same and your able to move a little faster. When increasing the speed you also need to take other precautions for safety. Like checking the brakes,tires and install Inertia Dampners. That way you can go warp speed without hurting you expensive engine. A rear end is way cheaper than another engine would be.
Please don't destroy the space time continuum!!
"Escapin' through the lily fields
I came across an empty space
It trembled and exploded
Left a bus stop in its place
The bus came by and I got on
That's when it all began
There was cowboy Neal
At the wheel
Of a bus to never-ever land"
DizzyIzzy is offline   Reply With Quote
Old 05-24-2008, 10:01 PM   #36
Chassis: Ford B700
Engine: Ford 370
I've got a 89 Ford B700 with a 370 2bl gas. I think it has a govenor but not sure. Been reading all the comments and have some question. How would I know if and what kind of governor i have? Seems like I can go about 55 mph and that is about it. Not looking for major speed, but would like to have some more power and speed when puling my boat. Also what would be a safe high rpm for this motor? Any help would be great.
Thanks
Jeb
talk2cfs is offline   Reply With Quote
Old 05-30-2008, 09:34 AM   #37
Year: 1980
Coachwork: Gillig 1980, 2003 Thomas E-350 shorty
Chassis: 636/E350
Engine: Cat 3208 NA/7.3
IT'S YOUR GEARS!! I've got a '90 Chevy/Carpenter 30' w/ 8.2T AT645 that will run 60-65 at 2800-2900 RPM.. This is a relatively high RPM motor, but prob shouldn't be run over ~2800 RPM for any length. I'm not an expert, but I suspect that if you had a governor, it wouldn't go over 3000 RPM with a load. If you want it to last, I'd try to keep it below 3000, better 2800. My bus will slow to 20-25 MPH pulling 5500 and 7500' summits between Winnemucca and Elko on I-80. My Gillig w/ MT643 CAT 3208 does the same. School bus + big hill + SLOW.
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
Old 10-07-2008, 10:15 PM   #38
GoneCamping's Avatar
I went to the Sturdy Road Speed Govenor website and requested info from them on adjusting my model 89 govenor. I got a phone call today from them, but they said nothing about cutting & splicing red & blue wires. First thing he asked me was where I bought the bus from. After being informed Harrisonburg Va he said that Virginia regulates buses at 55mph and that there were 2 things I could do to 'adjust' the road speed.
He told me to take it off the firewall and open it up, then remove the circuit board in there. After that I could call him, and he would tell me which 2 pins need to have a bridge soldered across them to attain certain speeds. He needed to know which ones were already "pinned" together before telling me what changes to make.
The other option was, that I could send him the board and that he'd do it for me (figuring I may not be up to the task of doing fine soldering work). Having a background in computer repair I told him I could handle it just fine. I only want to bump it up so that I can get 65mph out of this thing...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 10-11-2008, 09:45 AM   #39
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
And, on your Cat 3208, you can run it up to 3200 rpm safely. If you wanted to adjust the engine's rpm too. That's just a set screw on top of the engine. Probably the easiest diesel to adjust the gov.
nevrenufhp is offline   Reply With Quote
Old 10-14-2008, 08:49 PM   #40
Well, I'm back to square one. I went to remove the road speed governor on Saturday, and saw the wire connector with 3 or 4 wires coming out the bottom. I decided to follow that and see where it went, which was about 12 inches down and there dangled the other end, another plug with a connector on it....not plugged into anything!! Now if this thing is not plugged into anything, why can't I exceed 60mph? There is a cable that comes out and goes to the throttle body, but I can't figure if this does anything, considering the wires are not hooked up it can't be doing a thing.
Ok, exactly where is this RPM adjust screw located?
*Cliff*
new to buses chev49 Everything Else | General Skoolie Discussions 1 07-13-2012 11:45 AM
Chevrolet/GMC ignition retarder/govenor Kirbystud Conversion General Discussions 12 07-26-2009 01:15 PM
Party Buses (In Buses In The News) lapeer20m Everything Else | General Skoolie Discussions 4 07-03-2008 02:43 PM
Buses buses, ya wanna know about buses ??? frank-id Everything Else | General Skoolie Discussions 0 10-19-2006 11:42 PM
Crown ??? Crown buses??? The best of all the school buses frank-id Conversion General Discussions 1 03-05-2006 03:30 PM
