Old 10-14-2008, 11:17 PM   #41
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Re: How to adjust a buses govenor
On the 3208 it'll be labeled as, "high idle", as listed in the pic I included. Just 2 bolts(7/16" head) holds it on, then there's a screw & jamb nut under it. Loosen the screw (back it out, CCW)to raise rpm. Tighten up the jamb nut, and put the cover back on. Just keep it under 3200 & you'll be fine. Fuel economy drops drastically though. What does it tach at 60mph?
nevrenufhp is offline   Reply With Quote
Old 10-18-2008, 07:12 PM   #42
GoneCamping's Avatar
Thanks for the picture, hopefully I can find it and play with it. I don't remember what it was taching at, and won't be on the hiway anytime soon. But this is a project I wanted to work on so that the next time out I will be able to run at least the speed limit (65mph)...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 10-22-2008, 06:09 AM   #43
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Fuel Economy? You can get fuel economy with a bus?
Hard to imagine, huh? Never the less, I gained an additional 1+ mpg just by properly inflating my tires! Just a 1 mpg increase means an additional 60 miles out of my 60 gal. fuel tank, and every little bit helps. . .
Griff is offline   Reply With Quote
Old 07-24-2010, 04:07 PM   #44
Year: 1974
Coachwork: American eagle
Chassis: Silver Eagle
Engine: Screaming Jimmy 8v-71
Rated Cap: 46
I'm happy with my cummins 5.9 it will go 65mph but it like to cruise at 55- 60mph then agian I have a huge 10,000lb trailer on back!
"Thunder Bird"
Chadluc is offline   Reply With Quote
Old 01-18-2011, 10:10 PM   #45
Engine: T444E 3800
Rated Cap: 34
Not sure if this will help, but I took my bus to an International Dealer/Shop and they hooked up a computer to it. He said he could program the top speed up to 100mph, but the transmission, rear axle and top RPM's would ultimately limit the top speed. In a few seconds, my bus not tops out at a respectable 67mph from 57mph. And they didn't charge me! I have a 1997 International Bluebird... This has been the easiest fix so far!
Chuck Gbur
Go Bucks...
http://www.skoolie.net/gallery/index...es/PAIR-A-DOCS
cjgbur is offline   Reply With Quote
new to buses chev49 Everything Else | General Skoolie Discussions 1 07-13-2012 11:45 AM
Chevrolet/GMC ignition retarder/govenor Kirbystud Conversion General Discussions 12 07-26-2009 01:15 PM
Party Buses (In Buses In The News) lapeer20m Everything Else | General Skoolie Discussions 4 07-03-2008 02:43 PM
Buses buses, ya wanna know about buses ??? frank-id Everything Else | General Skoolie Discussions 0 10-19-2006 11:42 PM
Crown ??? Crown buses??? The best of all the school buses frank-id Conversion General Discussions 1 03-05-2006 03:30 PM
