Old 08-20-2012, 10:58 AM   #1
Year: 1985
Coachwork: Grumman
How to attach cabinets to aluminum body
One side of my bus/van is just aluminum without windows and I want to attach cabinets to the side (I'm using this as a headquarters for a race management company). What is the best methods for attaching the cabinets through the aluminum wall of the bus/van. Thanks
RunningMaryland is offline   Reply With Quote
Old 08-20-2012, 02:29 PM   #2
Year: 1985
Coachwork: Grumman
Re: How to attach cabinets to aluminum body
Did you pre-drill the holes? How large a screw? and you 've had no issue with them crashing down.
Old 08-20-2012, 08:54 PM   #3
Self tappers you don't pre drill the holes.. Use at least medium size fasteners, and the regular screws actually hold better if you use a small enough drill bit to just start the screws nicely. Self tappers usually have a fairly large drill bit end, which makes them not tighten quite as much.
I use both, and for things i want tight, i use the regular screws and pre drill the holes.
Be sure to put in lots of fasteners...
Old 08-25-2012, 10:30 PM   #4
lapeer20m's Avatar
i recently discoverd the best tool ever for putting in fasteners!
it's an impact driver. Looks like a regular cordless drill, but it uses the magic of an impact driver to do all the work. This tends to strip fewer heads, and also does not twist the arm of the person using the tool, unlike a standard drill, and it has about 10 times the torque of a standard drill.
when i say magic, i'm not kidding! How did i ever live without one of these! It's my new favorite tool.
Old 08-26-2012, 11:18 AM   #5
i have an 18v one.. and you can get drill bits for it at lowes that snap in to the bit chuck, and use the 1/4 drive adaptor to run your sockets...
Old 12-13-2012, 04:09 PM   #6
Engine: DTA360
Rated Cap: 16
I use self tapers on everything, I have been in construction for a number of years and built a lot of steel buildings with them... The impact drivers are a must when using them... Another tip, if you can get a c-clamp vise grip in the area to squeeze the materials together it helps a lot... And if you're using a regular drill to screw them in, speed is not your friend... Just like using a dill bit on metal, speed will heat up the bit and material... The tip of your bit, be it a self taper screw or drill bit will get trashed from heat... A lot of the time heat will temper the material and make it harder to drill thru...
dirtygoat is offline   Reply With Quote
How Did you attach your passenger seat? Stuff Conversion General Discussions 6 02-18-2011 09:30 AM
Best way to attach stuff to floor Stopbit Conversion General Discussions 1 04-01-2010 10:53 PM
What to use as flexible trim around cabinets/walls? Diesel Dan Conversion General Discussions 9 03-26-2010 06:38 PM
Upper cabinets advice needed Billsman Conversion Tutorials and How-to's 5 06-18-2008 07:52 PM
How do I attach a signature? suzy_F_homemaker Forum Admin | Account Help | Suggestion Box 6 07-19-2006 10:16 AM
