04-28-2015, 12:45 PM
#121
Chassis: Blue Bird
Engine: ISC 8.3
I've successfully used a heat gun to form PEX several times. IMHO, PVC pipe forms more nicely than PEX does, but they both accept it pretty well. Seems to me that the PEX is more prone to springing back than the PVC is. It took some practice to learn how to heat the pipe without blistering the surface, and how to heat a large enough area to just the right point so get a smooth bend without any kinking. I've kept an old toaster from the kitchen intending to dismantle and use its elements (nichrome?) to build a pipe warmer. Maybe it's time I actually did do that; there'll be plenty of places in the bus where a neatly bent plastic tube would be convenient.
04-28-2015, 06:05 PM
#122
1/2" PEX, not so bad. 1" PEX (what I have lying around) is a cast-iron-SOB. Heat gun or no it still wants to spring back.
04-28-2015, 09:15 PM
#123
Engine: 190hp 5.9 Cummins
Use it to make a bow and arrow. lol
05-06-2015, 06:00 PM
#124
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Random grounding question, based on my experiences in military field communications. Everything that's painted green, from tactical generators to maintenance shelters and trailers, all have grounding lugs on the power input panel, in addition to chassis grounds. Would a grounding lug to earthed grounding rod at the shore power input help add a layer of protection from a hot skin?
05-06-2015, 07:41 PM
#125
Chassis: Blue Bird
Engine: ISC 8.3
From an earlier post by jmsokol on this thread:
Originally Posted by jmsokol
And even pounding in an 8-ft ground rod really doesn't "ground" your RV. That's because the "ground" wire in the shore power line is really misnamed. It really should be called the "bonding conductor" which connects your RV chassis back to the service panels Ground-Neutral bonding point. This is what creates a high-current fault path which is what trips the circuit breaker to protect you from shock. Jack plates on the ground create a few thousand ohm "earth path" at best, when less than a 1 ohm fault path in the EGC is required by code. Even a properly installed ground rod can measure up to 100 ohms to earth and still be in compliance. It's really there to act as a path for lightning, and not as a ground fault path for 120-volt shorts. So yes, a ground rod DOES NOT ground your RV. Please don't argue with me on this because it's all in the NEC if you'll take the time to read it.
Having no exposure to military field comms I'm in no position to say what those grounding lugs are for. My guess though would be that they're kind of multi-purpose, to be used in a variety of ways depending on where and how the equipment is installed.
05-06-2015, 08:12 PM
#126
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I wasn't clear on how to do grounding for 120 volt either. Right now I have no connection from the 120 to the bus frame whatsoever (which I think is incorrect). So on one hand, if a + wire chafes through it will electrify the frame +120 and won't trip, but on the other hand if an outlet is wired wrong there is no way to electrify the skin. Not sure how is the right way to do this. I know there is a write up on it on here somewhere though.
05-06-2015, 09:12 PM
#127
If a piece of equipment has a ground lug, grounding it is almost never the wrong thing to do. Most of the time grounding is "wrong" is when you only THINK you have a good ground but really don't. Numerous guides and videos talk all about what can happen if your electrical hookup has a floating ground and how many parks are mis-wired. I've never actually been to one that was mis-wired (we stay at a lot of state parks, without power at all, and KOAs, where they go By The Book) but I don't disbelieve this can happen.
The first step of educating yourself, being aware of, and taking responsibility for your safety (instead of just trusting an outlet... or a well written post on Skoolies.net!) is the most important one.
05-06-2015, 09:28 PM
#128
Actually, to comply with both NEC and RVIA code, you need to have the Equipment Grounding Conductor (the ground wire) of in shore power bonded to the frame of your RV/bus. Typically that's done right inside of your AC circuit breaker panel with a big bolt tied directly to the frame. And as you surmise, without that ground-to-frame bond, it's surprisingly easy to hot-skin electrify your bus.
05-06-2015, 09:35 PM
#129
A ground rod's job is primarily to protect your RV/bus from nearby lightning strikes. It does very little to protect you from a hot-skin condition in the event of an open safety ground. In fact, it will only have sufficiently low impedance to drain down a high-impedance/low-current fault that's not really a dangerous shock hazard. Any low-impedance/high-current chassis fault will overwhelm a ground rod without a proper neutral bond back to the incoming service panel.
So while a ground rod may make you feel better. There's really no practical reason for driving one. Also remember that you can't just drive a ground rod anywhere you like. You should contact Miss Utility or other similar group to check for underground wiring or plumbing.
05-31-2015, 10:34 AM
#130
Wanted to chime in since grounding and bonding is a big chunk of what I do for a living.
Grounding is the connection of an electrical system to earth. Bonding is the connection of two conductive things together to make them electrically common. 99% of what we call grounding is actually bonding.
In a grounded 120VAC system, which is what all of us in North America are using at home, the neutral wire must be bonded to the ground wire (officially called the Equipment Grounding Conductor) at exactly one point, and that point also needs to be connected to the Grounding Electrode Conductor which goes to earth ground. There are rules about exactly where to do this in various situations, but generally speaking that point should be at the source of 120VAC power or as close as you can get to it.
If you bond the neutral wire to the ground wire at more than one point, you create a ground loop which causes some of the current to flow through the ground wire instead of the neutral wire. This is bad for several reasons including: trips GFCIs, causes EM interference for electronics, and is theoretically a fire and shock hazard. Dont do it!
So in an RV (or skoolie), with a shore power source, the neutral wire is bonded to the ground wire at the upstream power panel that feeds the outlet you are plugged into. You can make sure this is the case using a cheap 3 prong circuit tester (though if you want to frighten yourself but ultimately be extra safe, also read this about reverse polarity bootleg grounds, a dangerous situation that results from two separate wiring screw-ups).
Therefore, you should NOT have the neutral and ground wire bonded anywhere in your RV 120VAC system because then they will be bonded at more than one point. You DO need to have your ground wire, NOT your neutral wire, securely bonded to the metal frame/skin of the RV.
With an inverter or generator source, though, since you control the source of 120VAC power, you are responsible for bonding the neutral and ground wire. You should do this AT the inverter or generator. Some inverters and generators do this internally; check with the circuit tester, or use a multimeter to measure resistance between the ground and neutral with the power off. Make sure that the metal frame of the generator or inverter, if such exists, is also bonded to the ground wire.
In theory you are also supposed to have a Grounding Electrode Conductor bonded to the neutral and ground wire at the generator or inverter. The purpose of the GEC is (a) to provide a direct path to ground for lightning strikes and (b) to keep the metal cases of things at the same voltage as earth ground. In practice, no one is driving 2 8 foot ground rods 6 feet apart or whatever when they set up their portable generator, and I wouldnt do it either. I personally dont believe youre taking much of a risk by not having an earth ground on a temporary portable setup.
This does NOT leave you at risk of a true hot skin condition. You are protected from hot skin by having:
-A properly sized circuit breaker immediately downstream of your power source.
-Your ground wire bonded to your RV frame/skin.
-Your neutral wire bonded to your ground wire at your power source.
Hope this is helpful to somebody, I know it's a bit long winded, sorry! Best of luck setting up your electrical systems, its a confusing subject for everyone!
05-31-2015, 11:35 AM
#131
“Grounding” is the connection of an electrical system to earth. “Bonding” is the connection of two conductive things together to make them electrically common. 99% of what we call “grounding” is actually “bonding”....
Hope this is helpful to somebody, I know it's a bit long winded, sorry! Best of luck setting up your electrical systems, it’s a confusing subject for everyone!
Very good post which sums up a lot of what I write about in these forums. And note the I'm the author of the EC&M article you linked to above where I named the RPBG (Reveres Polarity Bootleg Ground) miswiring condition that's so dangerous. http://ecmweb.com/contractor/failure...esting-exposed
Mike Sokol
05-31-2015, 11:56 AM
#132
Very good post which sums up a lot of what I write about in these forums. And note the I'm the author of the EC&M article you linked to above where I named the RPBG (Reveres Polarity Bootleg Ground) miswiring condition that's so dangerous. http://ecmweb.com/contractor/failures-outlet-testing-exposed.
Mike Sokol
Thanks! I'm glad to know I got it right, it means a lot coming from an expert such as yourself! I had no idea you were the author of that article, I came across it awhile back doing unrelated research and have had it bookmarked since. Small world, huh?
05-31-2015, 05:50 PM
#133
Yes, it is indeed a small world. I started writing my No~Shock~Zone blog because a few of my pro-sound buddies said they had been shocked from their tour bus, and nobody could answer why. I took on the project as an intellectual challenge and found that the majority of electricians and technicians didn't really understand the basic differences between bonding and grounding.
While designing the schematic for a high-current 3-light ground tester I discovered that a bootleg ground condition with the polarity reversed would not be detected by traditional methods, but would still appear to operate normally. However, the entire chassis of the gear would be energized to 120 volts with a low-impedance connection capable of supplying 20 or 30 amps of ground fault current. I named this mis-wired outlet condition an RPBG for Reverse Polarity Bootleg Ground, but had trouble getting the test gear manufacturers to believe that it operated as I described it. They claimed their test gear could discover an RPBG, but after building the test rig as I showed in my demonstration schematic, they all admitted they had never thought about this condition and had not included it in any of their testing or documentation.
I'm seeing the same sort of confusion from the generator manufacturers over the issue of Neutral-Ground bonding and why it's necessary for RV electrical systems, but not for home electrical systems. Seems like a very simple concept to me, which is why I came up with the Neutral-Ground bonding plug as a solution for using a portable inverter generator such as a Honda EU2000i for power their RV. I've had literally hundreds of emails from RV owners who've built and use my G-N bonding plug successfully, but none of these same generator manufacturers want to admit that it works. That's why forums such as this are so important to spreading this basic knowledge. For reference here's the link to my G-N bonding plug article. Generator Ground-Neutral Bonding | No~Shock~Zone
Mike Sokol
www.NoShockZone.org
05-31-2015, 06:50 PM
#134
Thanks for the link! We will end up making something like that if we use a portable generator. Making sure all of the electrical stuff is safe and efficient is another reason we are building a skoolie instead of buying an RV!
07-02-2015, 09:54 AM
#135
Engine: 3126
AC ground to bus chassis
Mr Mike,
I have all my AC grounds isolated from my chassis ground. I will have ground from the campsite when plugged in, and I do verify that the campground is wired correct before per your example.
Now my question is my inverter is grounded to the chassis, so when I'm using it, my outlets are grounded to the chassis. Right now I'm manually plugging and unplugging the two. I want to put a switch in but all the ones I find only switch neutral and hot, not ground. Should I remove my inverter AC ground from chassis?
07-06-2015, 11:59 AM
#136
Chassis: B3800 Short bus
Originally Posted by wmkbailey
Mr Mike,
From post #130 (worth reading in it's entirety):
...You DO need to have your ground wire, NOT your neutral wire, securely bonded to the metal frame/skin of the RV.
The consensus is that you should always have an AC ground connected to your bus at a single point. If you do not then you risk having a hot skin condition. For instance, say you are plugged into shore power, have a circular saw connected into a bus outlet and are working outside with the tool. If that circular saw happens to have a fray in the wire it could electrify the skin of the bus without tripping the GFCI. That's a bad situation..
07-06-2015, 12:21 PM
#137
Chassis: Blue Bird
Engine: ISC 8.3
Check or test whether the inverter has an internal ground-neutral bond. If it does: you'll need to disconnect the inverter ground and neutral from the bus when using shore power, so that you don't create an extra ground-neutral bond in the shore power system you're plugging into. If the inverter does not: you should add a switchable ground-neutral bond to be installed when using the inverter and removed when using shore power.
07-06-2015, 01:57 PM
#138
Engine: 3126
All my AC grounds are connected together and not grounded to the Bus. When I'm on short power I get my ground from there. When connected to my inverter it is grounded to the bus through the inverter. I do this manually but plugging and unplugging them. I want to put in a switch but none of them switch the ground.
Sound like I need to keep my ground through the inverter, but need to find a switch that also switches ground. I'm surprised RV and Marine switches don't do this, they expect to have the grounds connected. If you don't check the shore power you could end up with 115 vac on the skin of the bus.
07-06-2015, 02:15 PM
#139
Perhaps I'm misunderstanding something here, but it sounds like you are saying that when you are connected to shore power your outlets are grounded through the shore power, but the bus skin is not grounded through the same shore power.
If this IS the case, then the scenario I described above is very possible. When on shore power you could potentially have a frayed wire touching the skin of the bus (pinched in a door, perhaps?) which will electrify it. No electrical safety devices will trigger.
Think of your bus as a washing machine for a moment. There are a bunch of live electrical components inside of a big, metal box. If those electrical components are insulated from the box and aren't somehow grounded to that metal box then if a wire comes loose from vibration or malfunction and that wire touches the box it will remain electrified. There is no path to ground to trigger the electrical safety devices.
On the other hand, if the metal box has a single connection to ground and a live wire contacts the metal box it will trigger the electrical safety devices and disable the appliance.
07-06-2015, 03:40 PM
#140
Engine: 3126
This is very confusing. I thought I read a lot about never having your AC ground to your bus chassis when using shore power. If there is a miss wire you could end up with 115 vac on the bus skin. I guess I miss understood. Now I have no idea what to believe. I guess I will reread everything and hope I figure out out.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Bus Electrical Systems - DC
Les Lampman |
Conversion Tutorials and How-to's |
65 |
12-13-2016 05:49 AM |
Leveling systems
lornaschinske |
Conversion General Discussions |
0 |
08-04-2012 10:42 AM |
Electrical Systems
noahyay |
11 |
07-29-2005 05:43 AM |
Sewer Systems
Steve |
0 |
06-16-2004 12:31 PM |
