Old 07-28-2018, 08:09 PM   #1
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
How to change tube in tire?
Anyone got a "how to" on how to replace my tube in my outer rear passenger tire?
Short version: had a tire shop throw some air in my tires. Drove around a bit (~20 miles or so). Came home, ate dinner. Went outside and heard a tire hissing. Looked at valve stem. Leaking where my finger is in the picture below.
Old tire. 9.00r20 tube type.
She's in my driveway at the moment but I'm trying to move out!
Ideas, thoughts, suggestions?
Trying to keep from having to get her towed. Thanks in advance.IMG_20180728_200712.jpegIMG_20180728_200701.jpeg
Nick
Old 07-29-2018, 08:28 AM   #2
Ninjakitty's Avatar
After talking to my step-dad who's owned a couple buses, it's not something I am going to.do myself. Split rims and tubes and no experience or the proper tools. Having a truck tire company coming out to do tube and put on a new tire as this one is super cracked and dry rotted
Nick
Old 07-29-2018, 12:33 PM   #3
if that bus is a 1990, its a retainer ring rim not a true split or 3 piece.. you still want to have some HEAVY chains or a cage to air up one of those..
"technically a retainer ring rim is easier for a DIY than a single piece rim, because you dont have to have massive tools to get the tire on the rim, and get the bead to seat, however if you dont know what you are doing that ring can still go flying... or the AIR from it can KILL you.. so yeah.. retainer-ring ring rims are still quite dangerous if you dont know what you are doing..
likely only a real truck tire shop will work on it..
Old 07-29-2018, 01:02 PM   #4
Ninjakitty's Avatar
It was is a retainer ring I think. It had one piece that came off. I called a mobile heavy duty truck tire place.
They brought a "new tire" just in case. That new tire was from 1998... Had the guy check out my current tire. He said the tire was fine and he wouldn't trust the "new tire" since it was 20 years old.
He put in the new tube in about an hour. Cost me $200. He recommended that when I get new tires, which I will in a month or so, to go to the 10r20 or 10r22 (not sure which he said), because that's what is common now.
Nick
Old 07-29-2018, 01:08 PM   #5
if you can get 22.5" rims go for it... most likely you'll need Budd STUD pilot type rims.. most modern are HUB pilot and there is a difference.. just because its a studded hib doesnt mean its hiub pilot.. it wont be on yours 99% likely..
if you have dayton spoke you can still have 1 piece rims.. I have daytons on my DEV bus and it has single piece 22.5" rims..
you'll have many more tire choices when you buy new tires if you switch to 22.5" rims.. you can go 10R22.5 or the most common 11R22.5, assuming you get the right rim.. 7" width minimum I think for most 11R tires.. 11R22.5 will give you a bit more rolling circumference too which will give you more top end speed if you are geared real low..
Old 07-29-2018, 01:12 PM   #6
Ninjakitty's Avatar
If I keep.my current rims, can I still get away from the 900r20 tires?
Any idea how much it would be to.switch rims? (Edit: looking at prices of new rims. $1500-2000 for the rims, new).
I really like.the idea of.goimg up.to the 11r22.5. it would give me that extra couple.of.mph I'm missing.
I appreciate your feedback Christopher. Thank you.
I'll take some pictures on the way out to home Depot
Nick
Old 07-29-2018, 01:35 PM   #7
with retainer ring rims from what I understand you are stuck with Tube and flap type tires.. these rims werent designed for tubeless. im not sure any tires were designed for these 20 inch rims that werent tubeless.. my advice is to keep a tube and flap with you all the time.. old-time truck tire shops will always be able to replace them... newer shops may refuse roadside service because of lack of cage..
for you youself be sure to buy a clip on air-chuck tire inflation hose with a gauge and valve in it.. when you inflate, your stand with your body inline with the tread and not perpendicular to the tire..
generally retaining rings wont fly off of a rim where the bead is set.. the design is that the setting of the bead and more pressure on the bead tends to seat and hold the ring in place.. but like anbythiung thats design, thats not failure..
even on my regular tires i use my clip on chuck and stand away from the sidewalls.. a blow-out of a regular tire.. the AIR (no metal or rubber flying).. the AIR alone can seriously injure you.. not likely.. but.. for a 50 dollar tool and a little sense its worth it for me to be careful about my tires..
I bought this one..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-30-2018, 12:29 AM   #8
Ninjakitty's Avatar
Thanks again for the advice. I will follow it.
Talked with the wife, I think before we roll out we are going to go ahead and change the rims to 22.5 that we can go tubeless on.
Nick
Old 07-30-2018, 04:53 AM   #9
Are you on budd hubs or Dayton spoke? I’m interested to know what you find as far as wheels if you are budd hub ,
Christopher
Old 07-30-2018, 09:14 AM   #10
Chassis: B3800 Short bus
Yeah, I want to know now, too Budd or Dayton style? From the above pictures it sort of looks like Dayton style, which is good news from an affordability stand point. I know around here I can buy a new Dayton tubeless rim for $125 CAD.
