Old 07-15-2009, 07:10 PM   #1
Year: 1985
Engine: Detroit Diesel 8.2L
How TO: Check kingpin wear/cause of uneven tire tread wear
I need new steer tires on my skoolie. The front right tire is significantly more worn on the outside of the tire. I've been told it could be worn kingpins. I jacked it up and tried to jiggle the wheel perpendicular to the plane of rotation of the wheel, but could not detect any play. Do the kingpins have to be removed to check for wear or is there a better way that I can check them myself? Do you think I should have the tire shop check it out when they do the alignment? thanks, Phil
Ischgnibargle is offline   Reply With Quote
Old 07-15-2009, 08:41 PM   #2
Chassis: Ford B700
Engine: 5.9L Cummins
Re: How TO: Check kingpin wear/cause of uneven tire tread wear
I'm sure there is a correct way to check the kingpins but an alignment should give you a good indication. When they are bad you can usually see it when you look straight on the front of the vehicle. The top of the tires will lean inwards pretty bad. Your wear seems to be on the outside which could be ball joints, bad alignment, bad tires (when they start a wear pattern they will continue to wear in that same pattern no matter what you do) or possibly the kingpins although I think bad KPs would usually wear on the inside of the tire.
kamoo is offline   Reply With Quote
Tread for steps Atridox Short-Bus Conversion Projects 4 04-04-2010 09:41 PM
Kingpin replacements? TygerCub Conversion General Discussions 2 06-09-2009 09:54 PM
Check this out Redbear Everything Else | General Skoolie Discussions 5 04-24-2009 05:37 PM
Tire Tread Elliot Naess Conversion General Discussions 3 12-01-2008 06:46 PM
Uneven tire tread wear the_experience03 Everything Else | General Skoolie Discussions 11 05-17-2007 02:58 AM
