Old 09-12-2007, 12:28 PM   #1
Year: 1952
Chassis: Chevrolet
Engine: 5.7 Proposed
Rated Cap: 12
How to inspect OLD bus before buying
I am days away from writing out a substantial check for a 1952 Wayne/Chevy short bus. It was converted probably before I was born, and has been sitting in a pasture for the last twenty years. The conversion is absolute trash. My specific question is, on a bus of this vintage, what are the hidden issues? Is this a double wall body that can trap moisture and rust from the inside out? Where do I start to look?
A check list would be great-
Motor/trans running gear will get upgraded so I'm not real concerned about all that business; my concerns would be any vintage Wayne body issues.
Great site, learned alot already!
Thanks in advance-
Paul
http://www.flickr.com/photos/13278824@N03
barxracer is offline   Reply With Quote
Old 09-12-2007, 03:15 PM   #2
the_experience03's Avatar
Re: How to inspect OLD bus before buying
Gorgeous...truly gorgeous.
Mechanically I'm not sure what your plans are, but it would seem to me that the vast majority of people end up repowering those older rigs with something a bit more modern.
I would spend a lot of time accessing the actual coachwork. I guess if I were picking up something that old I wouldn't worry TOO much about what the interior looks like or wiring or that kind of stuff, but I think the sheetmetal and framing would be of interest to me. Framing could almost be fabricated to work if the need was there I guess, but the sheetmetal and the special, unique little hardware stuff...well....it might not be replaceable.
How much of a project are you looking for? What's the plan? I'm jealous of that find, no matter the condition.
Old 09-12-2007, 03:33 PM   #3
Year: 1952
Chassis: Chevrolet
Rated Cap: 12
The plan is to build a clean "retro-rod" with modern powertrain. I have seen a few posts about trapped moisture and it got me worried. This thing seems like its built out of boiler plate, but rust can take anything down in time...
Most of the hardware is present. The conversion that exists is going straight into the dumpster. I wish I could look under the flooring and behind the cabinets, but I don't think this guy is going to let me dismantle the old girl out in the pasture.
Old 09-12-2007, 03:48 PM   #4
Steve's Avatar
The good news on these old buses is that rust is easy to repair given most of the metal is flat. Look under the rubber floor on the stairs there will certainly be rust there. A lot of buses have wooden floors, you will want to pull up the floor and inspect it, but you shouldn't be too worried about it if you have also have to repair the floor.
Old 09-12-2007, 07:08 PM   #5
davido's Avatar
I have a '58, '64 and recently bought a '63 (to span the gap parts wise). The major rust areas I've seen are either the firewall/back fender area (one was from IL) and the floor under water sources (rusted through). The rounded bottom edges of that one was rusted out in several areas. Enough so that I would ahvce to come up with something creative if I were going to make it open floor. I've no rust issues in the roof area. Even if it gets inside, I think it runs down and basically boils out with all of the heat. Be prepared for a lot of work if you really want to get it all straight. They're a lot of fun, but a lot of work. Huge PITA to move when they're not under their own power. (Actually scratch that somewhat, I just saw your pics. Shortie. Nice.)
I'm not sure what you're spending, but I've never paid more than $300 for one. I have yet to replace any axles or anything like that. None of them ran. One was in running condition, but I didn't buy the engine ($700 additional). It wasn't the engine I wanted, but then it took me a year to replace it so I probably should have just bought it anyway. I think you're working with a totally different budget than I ever have. That's fun. I've been wanting to pick up a modern diesel donor bus, but I haven't gotten that far. Be sure to keep posting up pics. Sounds like a cool project.
Here's a few pics of my first two. The '64 has just recently gotten officially road worthy: http://www.skoolie.net/gallery2/v/Skoolies/Vintage
davido is offline   Reply With Quote
Old 09-12-2007, 09:39 PM   #6
1952 Wayne/Chevy/Cadillac 500ci resto rod
Old 09-12-2007, 10:52 PM   #7
davido's Avatar
Originally Posted by jimmyaustintx
Hey davido did you get that 63 that was here in Austin....
Sorry, don't mean to hijack your thread.
Yes, thanks for the heads up. It has the front clip that I need to replace my rusted out '64. It also has a good enough body and rounded top front so that I can later use it to build as a "58" with that front clip. The chassis of my '58 and the current '64 front clip will likely see the scrap pile in the next year or so.
Old 09-13-2007, 12:49 PM   #8
Year: 1952
Chassis: Chevrolet
Rated Cap: 12
I am probably going to be upside down in this project from the start. I believe it is worth a little more because it is a factory shortie. Everyone that I have shown the pics to thinks its a shortened regular bus. I have found 1 unit like it, but have no info on it. Every other bus I have found that vintage twice as long and are missing lights, wipers, mirrors, - stuff specific to the Wayne body. This one has 99% of that stuff.
As far as my budget for the project, Its hard to say. I could estimate, triple the figure and still be short. For starters, I think I'll strip out the conversion have the body media blasted inside and out and spray it with Variprime, if for no other reason than to get the mice and mouse smell out. It won't fit in my shop, and Dad won't let it in his shop if its full of mice.
There is a restoration shop near Ashland Nebraska that seems to be reasonable with blasting costs.
I think most of you understand the multi-year project, and this will most certainly qualify.
Old 02-11-2008, 09:22 PM   #9
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
barxracer did you buy this bus? how is it going? timbuk
Old 08-18-2008, 06:04 PM   #10
Year: 1966
Coachwork: supierior
Chassis: Chevy C60
Engine: Chevy 454
Rated Cap: 10
Make sure the axels, hubs are good, hear in southern california they are hard to find, i had to go to tijuana to find mine. Also look into brake parts these are gunna cost a fortune, mine the wheel cylnders alone where 800 or more total, So you may want to just put newer axels under it in the first place. Hydrovac sucks, but BSC brake parts warehouse has rebuild kits for em just ask for rick
junkyardkid is offline   Reply With Quote
Old 08-18-2008, 07:03 PM   #11
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
chevy c60.com
Old 05-21-2011, 09:36 PM   #12
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
I recently looked at a 1971 Carpenter/Dodge in western Iowa. Overall, the body was in excellent condition. I didn't buy it because I decided to wait and find a longer rig.
One thing, though, is that the underside had surface rust throughout. Looked pretty light, not crusty, no holes anywhere. Any thoughts on how to evaluate for what level of work needed to deal with this? Would "Ospho" be sufficient as long as the metal was solid? (As for the outer body, I'd want to strip the paint until I had a good substrate for my own paint job.)
The engine was recently rebuilt and the clutch plate replaced. The 4-speed stick worked great. I drove it on a farm road and it felt like it was smithed out of one hunk of steel.
Awesome! I live in nearby Omaha. I hope they're still in business by the time I eventually get a bus.
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 06-02-2011, 10:21 AM   #13
Skunky Bus's Avatar
Engine: 360 V8
Here is a photo of the undercarrage of a 2000 model year bus I just saw on eBay. The picture is from the listing. (The bus is in New York State.)
If memory serves me correctly, the 1971 bus I looked at last year was actually better. Any thoughts on how whether this can be dealt with? I still would rather fix up a classic, so info for future reference would be useful, since "rust-free oldie" is something of an oxymoron.
Old 06-02-2011, 10:47 AM   #14
Stuff's Avatar
a light sandblasting and undercoating is all i can recommend...
Old 06-30-2011, 05:56 PM   #15
Skunky Bus's Avatar
Engine: 360 V8
Here's a 1966 bus I just saw in Iowa: Just an interesting example (combined with the Y2K bus pictured above) of age not predicting degree of rust. I think what's there would sandblast off well.
Old 01-09-2012, 03:26 PM   #16
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
hey the older the bus the cooler it is,just look out for ROT AND mold
Buying a bus tesswynn92 Skoolie Conversion Projects 10 08-13-2014 04:24 PM
Buying first bus! cschlessman Conversion General Discussions 1 06-22-2012 04:35 AM
After buying... LOrOLR Conversion General Discussions 4 09-08-2009 01:33 AM
Buying a first bus gmkdart Conversion General Discussions 1 08-03-2008 03:00 PM
Buying Bus code4 Skoolie Conversion Projects 18 10-23-2005 04:40 PM
