Old 09-24-2015, 09:46 AM   #11
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I'm planning to run one stock rear bus heater in the restroom, and one in the "cab" that I'm going to section off. I'll have 100k+ btu's in the cab!
Old 09-24-2015, 10:27 AM   #12
The factory bus heaters that operate off the coolant are excellent. Big and clunky, but put out a lot of otherwise wasted heat over the road. As for propane, catalytic heaters are far and away the most efficient.
Old 09-24-2015, 02:10 PM   #13
You silly FL peeps don't know what to do when it gets below 48*
Old 09-24-2015, 02:52 PM   #14
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Nope, I sure as hell don't!
Old 09-24-2015, 05:56 PM   #15
#smartenoughtoleave
Unless there is some really damn compelling reason I would up and leave.
CaptainInsaneo is offline   Reply With Quote
Old 09-24-2015, 06:12 PM   #16
opus's Avatar
Chassis: All-American R/E
I use a Webasto.
Old 10-09-2015, 11:31 PM   #17
Wood burning stove
MradamX is offline   Reply With Quote
Old 10-10-2015, 09:11 AM   #18
i used a webasto knock-off called "Planar" diesel fired heat.
the problem i had with the heater is it doesnt burn right over 9000'. when it fires up... it just smokes, a lot of smoke. looks like cheech and chong are camping with white smoke billowing from the exhaust. i think the webastos have the same warning, not for high altitude heating.
for high altitude heat i had to get a heaterbuddy portable.
Turfmobile Build Thread
Old 10-10-2015, 10:38 AM   #19
opus's Avatar
I'm sure at 9000' you'd have to lean the Webasto out some.
Old 10-10-2015, 07:58 PM   #20
Chassis: Genesis
There are high altitude kits for both Webasto and Espar units. The Webasto one increases fan speed and the Espar one apparently decreases fuel.
Timelord is offline   Reply With Quote
heating, insulation
