Old 02-24-2016, 04:59 PM   #31
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
No experience YET with underfloor spray-on insulation. But, I DID have carpeting/linoleum installed. Those two items alone will insulate the floor and help make it a bit more habitable. Mind you, the flooring set me back $700 and the installation another $500. But I don't have any sweating.
On the walls, go to your local big-box hardware store and purchase some 1" double-faced rigid foam panels. For a big bus, you'll need 8 4'x8' sheets for the sides and an additional two for the windshield and door. That'll set you back about $200.
Old 02-24-2016, 06:20 PM   #32
11 below ZERO
I would like to offer some first hand FYI experience on heat. Propane produced the worst humidity problems of anything I have used. Kerosene is a close second. In both cases, you are burning petroleum products. I love burning dinosaur juices but ventilation IS ABSOLUTELY a life or death decision.! Yes, buses are pretty leaky but not so much that you can close it up. The cross flow of one fully open window combined with all the leaks seemed to do the trick so long as the window was down wind. If not it'll get pretty chilly, pretty quickly once you get below about 25*. The closer you get to single digits the harder it is to ventilate and not lose too much of your heat. At times, you may need to adjust the window a couple of times during the night. Not really so bad but I'd rather be sleeping. At (-11*) it took the wood stove, two kerosene heaters and a Lil Buddy propane heater just to get to 63*. But hey, 63* is fine with me.! Don't be surprised if you can leave that (ONE) window wide open IF it's the only one. Once the wood stove was up and running, the only purpose to the kerosene or propane was to provide a faster warm-up while the stove builds up to operating temperature. Biggest thing to note is that the wood stove does NOT produce the moisture problems like propane or kerosene. To the disdain of my cat, I was not heating the bus while I was at work. At 4-3/4lbs she knows how to find her way under the big blanky.
Knight Rat is offline   Reply With Quote
Old 02-24-2016, 06:23 PM   #33
Oh... and the wood stove just about eliminated any moisture problems.
Old 02-24-2016, 06:36 PM   #34
Chassis: Blue Bird
Engine: ISC 8.3
I've never applied under-floor foam, but my bus does have it. I think it was factory applied. 280k miles and 15 years later it's still in pretty good condition. Unfortunately I don't have any before-and-after data to be able to say how much difference it makes. Mine doesn't have a smooth surface like you might expect from watching the spray foam how-to videos on youtube. It looks like it was applied one spot at a time, like a thousand foam stalactites clinging to the bottom of the floor. They're about 2-3 inches diameter at the top tapering to a point where the flow cut off and the sprayer moved. It's kind of like a row of frosting squirts decorating the edges of a cake..
Any kind of combustion inside the bus will raise humidity levels and provide more vapor which becomes pools on that cold floor. If you can heat the place while controlling the vapor that'll help keep things drier even if cold. A wood stove does this by exhausting via its chimney for example, whereas propane or kerosene heaters vent their exhaust and water vapor into the space being heated.
Old 02-24-2016, 06:59 PM   #35
Robin97396's Avatar
I actually do have my feet resting on a wood stove in the bus. I didn't get the pipe hooked up to exhaust the wood stove. I had begun using propane so eventually I've put the ceramic heater inside the wood stove. The wood stove gets hot and I think it's burning the propane more efficiently in a protected environment. It was cold in the bus while it was freezing outside while heating on propane. That's a lot of steel and glass to try to keep warm.
Old 02-24-2016, 07:13 PM   #36
Robin97396's Avatar
Do most of you guys actually strip out the interior of your bus so you can insulate, wire and plumb them? So far I'm still going with the a'natural bus with 4' long power strips from Harbor Freight for power distribution. Buses are remarkably safe vehicles. Problem is there's a couple cold months when heating is a problem. I like the "head south" idea.
You're all right, the wood stove will take care of the moisture problem. I'm sure wishing I had one of those pellet stoves made for tent camping.
Old 02-24-2016, 07:26 PM   #37
Chassis: Blue Bird
Engine: ISC 8.3
Eek! Make sure you're getting plenty of oxygen in there. A ceramic heater normally burns well with very little carbon monoxide produced, but if the oxygen supply is limited.. for example by being inside a closed box.. improper combustion can result, with increase CO as a likely outcome. Also the heater could overheat.
Old 02-24-2016, 08:20 PM   #38
Robin97396's Avatar
Family Wagon; just try sealing one of those buses up during freezing weather. They leak like a sieve. I wanted to try living in the bus during freezing weather and it wasn't terrible. Still a lot like camping. Yes, lots of fresh air. I still have the original doors which don't exactly seal tight. A veil of plastic over the windows makes a marked difference. I prefer black plastic over my tinted windows. You ever tried sleeping in one of these things? They seem pretty bright inside early in the mornings, but then I kept all the windows. Yeah decisions, decisions.
This bus looks like a class A motor home with a school bus paint job, with the exception of the windows. I like the anonymity of a school bus paint job because nobody looks at buses twice.
Old 02-26-2016, 01:09 PM   #39
Originally Posted by paul View Post
Hello,
Paul here. I have a question for you guys, how does one go about the process of keeping a skoolie warm in the winter? I already have planned out the walls, (inserted with pink insulation). Ive been planning on using multiple electric heaters, to keep the place warm. Is there maybe a way to seal off the windows?
Please just comment anything that you think is useful to know about heating...
thanks,
yours truly;)
I am playing with a hot water circulation unit under the floor. But I have also used a coal stove and of coarse propane. But hot water I believe would be the best...
buslife4all is offline   Reply With Quote
heating, insulation
