Originally Posted by golfersmurf57
I'm not familiar with the T444, but if it's individual plugs there's either a wire to each or a copper strip with a wire to one end. Take a test light and test for voltage on initial key on. It may have a light on the dash it should light for a short ( 10 secs at most) then go out. Voltage should be present at the terminal of each glowplug. This doesn't mean they're good. To test each, remove the wire or copper strip place the alligator clip of your test light on the positive terminal of the battery then touch each plug terminal. Good plugs will light bad ones won't. If they are all good take a jumper wire and connect it to battery positive then touch it to one of the plugs through the back of the connector for approx 5 secs then crank the engine it should fire and run. If it doesn't you have other issues. Oh make sure they're all connected up before applying the voltage manually. And never use starting fluid on a glowplug engine. You could damage it or yourself. Let me know. On the Ford's and chevy they usually screw into the cylinder heads near the valley cover. They have a spade terminal and usually have a 10 Mm wrench size bolt face
Sent from my LGL64VL using Tapatalk
Sorry bud, but on the T444E the glow plugs are under the valve cover, they need to disconnect the valve cover wiring harness and check power there. One can start at the glow plug relay first to see if the relay is even good, they fail.
The GPs only stay on upto 2mins then they are cut off depending on what the ECM determines based on intake air temp.
RIGHT NEVER USE STARTING FLUID ON THESE, that is a great way to bust a ring or rod. I've parted out several 7.3 powerstrokes because of stupidity, I call starting fluid "idiot spray". LOL.
The connector on the glow plug is round, not a spade.
On these 7.3s there is a wiring harness built into the valve cover gasket, they can also become damaged and leak oil through the connector burning out connections which sometimes causes them to run like crap because injectors are likewise on the valve cover and wiring of them is in the same harness with the glow plugs.
I have several videos on 7.3s my YT is "Patrick Baptist" but I've yet to make bus videos but the engine is the MOSTLY the same as the T444E.
Eventually my bus videos will wind up there, I just haven't had to do anything to mine yet, it's a 04 IC RE with the T444E and mated to a Allison MD3060.
But if you check my YT I have a video on changing the glow plugs.
