Old 07-18-2012, 10:52 PM   #1
opus's Avatar
Chassis: All-American R/E
Re: How to tell if a bus is geared for highway speeds
Knowing what engine it is will tell something too.
Old 07-20-2012, 09:29 AM   #2
since its a 99, there are lots of things that will be fine. and so far its below scrap price at 2k. and i imagine that it was maintained well.
Old 07-20-2012, 03:00 PM   #3
GreyEagle's Avatar
With it's previous life being an airport shuttle bus ie (from airport parking lot to the airport and back) it's a good bet it's geared pretty darn low don't your think?
You could use the (ask the owner a question link) and maybe get some answers to your questions, sure can't hurt. All info on here will be only guesses unless someone is there with the buses..
Great looking bus tho ...... I'll bet they're built as well as the school buses and probably a lot quieter too....... again only guessing...
Best of luck in your search
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 07-20-2012, 05:29 PM   #4
fwiw.. you should be able to look up revs / mile from the mfg.. dont know about retreads like from les schwab, that may be in their retread book, but when i was looking at it from of the retreaders locally i forgot to look.
am talking abt 22.5 or 24.5 tires...
of course circumfrence can always be measured and figured it out from there...
Old 07-22-2012, 02:31 PM   #5
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
if u have blue bird it will give the ratio on the spec plate above the drivers window mine is 478 runs out at 58 mph do to the pump .so if i change the rear it won't help because of the pump,and it can't be turn up per cummins.
keith is offline   Reply With Quote
SKOOLIE - Governed or Geared? heathnlaura Conversion General Discussions 30 06-26-2013 08:04 AM
Can a transit bus be made to go faster for highway speeds? lornaschinske Mechanical and Drivetrains 5 04-16-2012 10:29 AM
Throttle Sputter at high way speeds jaredg Mechanical and Drivetrains 3 11-04-2011 10:51 PM
Havoc on the Highway the_experience03 Skoolie Conversion Projects 11 06-27-2006 09:18 PM
highway speeds/mileage? frogee Everything Else | General Skoolie Discussions 2 04-08-2005 11:52 AM
