Old 01-28-2020, 06:03 PM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Icynene ProSeal Spray Foam Instructions inside
Don't know if this will be of any use, but these are the directions for the spray foam we'll likely have professionally sprayed (already talked to installer & this is what they use). I found it useful to understand the temp ranges, substrate properties (like galvanized needing to be primed), signs of a bad mix, etc.
https://www.icynene.com/sites/defaul...ns_7.22.19.pdf
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 01-29-2020, 03:23 AM   #2
Thank you for posting this, It may come in handy for those looking into using spray foam.
