Old 04-29-2012, 03:58 PM   #1
bus-bro's Avatar
Engine: 3208 na boat anchor
Inside bus LED lights
I installed LED lights in the existing interior lights. I wired a push button switch in each one. When engine is off, lights are powered by the house battery bank. An order of magnitude brighter, and uses less power than the incandescent bulbs that were in there.
$20 for the LED units from Super Bright LEDs. the swich was about $3. The total cost was about $25 a light.
Old 04-29-2012, 05:11 PM   #2
Engine: International T444E
Rated Cap: 71
Re: Inside bus LED lights
That is super sweet.
mchunt is offline   Reply With Quote
Old 04-29-2012, 05:57 PM   #3
bus-bro's Avatar
Thanks.
Old 04-29-2012, 06:45 PM   #4
i have the mr16 base 3 watt lights that cost 13.00 for 5 of them in my bus. entire 40' thing only has 12. i think they equal 50 watt regular bulbs.
Old 04-29-2012, 07:03 PM   #5
bus-bro's Avatar
Just curious chev, what kind of bulb is that, i.e. incandescent, fluorescent, halogen, LED ?
Old 04-29-2012, 08:46 PM   #6
just go to ebay and look up 12v mr16 bulbs. most are three bulb led's and you can buy bases for regular 110v lamp and wire 12v to it, or bayonette adaptors also. there is also the type you have on ebay also, but i use these light bulbs that have 2 prongs and also buy the adaptors very cheaply from hong kong. the bulbs are best bought from california
Old 04-29-2012, 09:35 PM   #7
bus-bro's Avatar
Be nice to have a link to it. I'm not saying that what I'm doing is right. And twenty-five bucks a light sure adds up fast in a 35' school bus, a BB AA at that. In fact most of my bus projects are iffy, to say the least. Just see my tutorial on building your own waste tanks out of plywood, styrofoam, fiberglass, and a couple of gallons of epoxy. If an RV park were to ask "Will it leak?" I'd reply: slowly, only slowly. (The tank doesn't leak, it just hasn't been road tested yet--if you know what I mean. )
Old 05-01-2012, 07:54 AM   #8
Chassis: Genesis
Engine: Dt40
I did the same thing with led's I got at Autozone.
bhays is offline   Reply With Quote
Old 05-01-2012, 09:11 AM   #9
When i build the slide out after we get back to our other property, i am gonna toss out all my plastic holding and fresh water tanks and build all new ones that will fit the exact shape of the compartment it is in... i am wasting too much space having 5 fresh water and 3 grey, etc..
Old 05-04-2012, 12:59 PM   #10
bus-bro's Avatar
Dragged this post over from a Conversion Disscussion thread:
Chev49's link ...http://www.ebay.com/itm/160734295819...819%26_rdc%3D1 .
Nice price.
Heres a link to what I used (I used that warm white 9 hi power LED board): http://www.superbrightleds.com/cgi-b...%2Fpcblamp.htm .
Price not so nice, and a bit delicate to mount. IIRC correctly, with 10 of 'em lit I use about 1.6 amps of 12v power. That would be 19 watts for 10 lights.
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood Gasification, etc. 2 12-14-2011 11:32 AM
inside doors gbstewart Conversion General Discussions 2 05-02-2011 10:53 AM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 05:19 PM
Pine Boards Inside Bus arfisher83 Conversion General Discussions 6 01-07-2008 07:26 PM
Cleaning inside of the bus? KC10Chief Conversion General Discussions 4 02-28-2007 07:20 PM
