07-25-2016, 09:19 AM
Chassis: international
Rated Cap: 71
Inside doors
Hey guys
I'm trying to see what people do for inside doors for the center of the bus. I'm not doing a roof raise so I wanted to see how the top of the door fits so there is no gap if you can but also were you won't have to duck for any frame. I have never built door frames so I don't know if what I'm asking is possible or not.
07-25-2016, 10:51 AM
Chassis: AARE
Engine: 3116 Cat 250hp
Why is it necessary to go all the way to the top, or bottom for that matter? Are you trying to seal a room off for some reason? Interior doors don't really need to do anything but block view, or rarely lock to keep someone out.
07-25-2016, 09:47 PM
Rated Cap: 71
More of just the way I'd like the doors to be more than anything.
07-25-2016, 10:04 PM
Here's our only door, a nylon strap is the curtain rod so no one (our size)bumps their head.
All walls are open at the top, no steam build up and good air flow. The toilet is right around the corner in the same room.
Don, Mary and Spooky the cat.
01-02-2017, 12:09 AM
Lol, Your comment isn't at all helpful to the question at hand. What is asked of everyone is what kind of DOORS have people created or bought for room separation, not a table cloth, blanket or bed sheet. For example a door for your toilet, or for the master bedroom. Privacy and odor control are on most people's list's.
What I plan for my rig are pocket doors with a spring loaded latch to lock in place when either open or closed so they don't just slide back and forth when driving around corners or on hills. That's what I'm planing for but it may just end up being those accordion style RV doors, they're lite and super easy to install.
01-02-2017, 06:51 AM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
I M O any doors that roll or swing in a moving vehicle suck. i ripped a door off its hinges a few times in my T T. no matter what lock or foot i put on it. the bouncing and swaying will outsmart about any lock you put on them. im going with the accordion door.good luck
01-02-2017, 08:23 AM
I installed dual sliding pocket doors here http://www.skoolie.net/forums/f10/bu...oor-14708.html
Since the walls aren't finished when I move, I just use a couple handy clamps on the top rail to keep them from sliding back & forth.
01-02-2017, 08:57 AM
Year: 90
Interior doors.
Residential interior doors come in many dimensions. I used 2 closet doors, frames and all. only had to make them a little shorter. Even used residential door latches with sucess
01-02-2017, 10:34 AM
Rated Cap: 34
Nicely done, REDD........what is that white trim around the top of the partition made from?
01-02-2017, 10:47 AM
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Thanks, Ended up using almond coloured silicone on both sides of both walls, taped both edges to get a smooth finish then pulled tape off. Went to a RV parts store and got 4 samples of rubber weather stripping for molding, wouldn't work around the wire chase...to tight of a bend. So, silicone it is...
01-05-2017, 07:05 PM
I am stealing that tip with the tape. I've used it painting before but didn't think to apply it to sealant. Thanks!
