Old 02-03-2015, 08:25 PM   #1
Talking Insulation and heating
hi guys,
I was just wondering, if you don't add on additional walls with insulation, onto the bus walls, would it be excessively hot/cold...also, if so any good heaters out there? Any pointers appreciated.
thanks! ;)
paul is offline   Reply With Quote
Old 02-03-2015, 09:52 PM   #2
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by paul View Post
hi guys,
thanks! ;)
That's all subjective.
I wouldn't wanna live in a tin can with a metal interior.
Old 02-03-2015, 10:08 PM   #3
Nimbus's Avatar
Coachwork: Ford
I'll say Living up north, that before i Insulated my bus even just the floor and most walls. it went from not holding heat really at all, to staying warm when its -20 outside with just a space heater
Nimbus is offline   Reply With Quote
Old 02-03-2015, 10:23 PM   #4
lornaschinske's Avatar
Rated Cap: 89
Creating the thermal barrier made a big difference. NM experiences temp ranges from single digits to triple digits. I heat with two Patton Utility Milkhouse electric heaters. I also have a small Tag-a-long LP heater in the bathroom area to use for short periods of time (bump the heat up when I shower or get dressed in the early AM) and an LP fireplace in the salon. I find the electric heaters do not do well when temps drop below 35-40F. The LP heaters do work.
My Blue Bird has stock insulation in the walls and ceiling. Furred out the side walls to creat thermal break and added 1" rigid foam sheathing with a foil heat barrier (facing towards living space). Small cost for insulation makes a big difference in the heating and cooling. Big differance from when we first moved into the bus (in winter) with no additional insulation or thermal breaks (I got a blister during the summer from a rivet in the sidewall).
Fulltime since 2006
Old 02-04-2015, 09:11 AM   #5
Engine: 190hp 5.9 Cummins
At -20 c up here in Canada, I had to run my wood stove full throttle before I insulated. One side of me was cooking, the other side freezing.
Now I run the stove one 10th of that to keep warm.
My current set up is a bit different than most of you will have. The original bus shell is my interior, and I insulated on the out side with 6 inch fiberglass bats, then skinned with roofing tin. My outer metal skin never touches the inner skin, creating the thermal break to avoid condensation and heat loss.
Now lets talk about thermal mass of various materials.
Rigid Styrofoam has almost no thermal mass, and there for is what I will call "Thermal neutral. This means, no matter how much heat or cold I expose it to, the Styrofoam will not soak it up, and radiate it back into the room.
Wood is in the middle of this list. It is a insulator, but not a good one. It still contains enough thermal mass to take the heat or cold and radiate it back into the room. Just not very well.
Materials like steel have large thermal mass numbers. It absorbs the heat and cold and radiates it back into the room.
My wood / coal stove works well for me because of my inner steel shell. The stove radiates the heat into the steel, the steel holds the heat, and radiates it back into the room.
If I had a Styrofoam interior, my stove would not work well. The stove could only heat the air, and air has almost no thermal mass. Heating air is the most inefficient way to heat.
My new bus I'm building, "The Four Season Prime" will have no thermal mass anywhere except the floor. The floor uses sheets of 14 ga steel laying over the hot water heating lines as a subfloor. This steel will grab the heat from the heat transfer plates the water lines lay in, and radiate it up into the living space.
Thermal mass is good and bad. A cement shop floor contains large thermal mass. It can take days to bring up to temp, but also takes days to cool. This is not ideal due to if you get it uncomfortably hot, the floor takes time to cool down. This is why I was careful when engineering how much thermal mass to build into my floor.
I don't like propane heaters due to the danger, and the awful moisture they give off. Lorna likes her propane heater over the electric due to the moisture in the air increasing the thermal mass. The right amount of moisture is good, but too much is bad. All electric heaters give off extremely dry air.
Radiant heat is what makes life on this planet possible. The radiant heat from the sun travels millions of miles to earth. On this path it passes right through area's of minus 4000 degrees C, but it still gets here.
Air being a having almost no thermal mass and being a poor transmitter of heat and cold is what makes insulation work. Tiny air pockets trapped inside the insulation is what stops the transmission of the heat and cold.
So all in all, Thermal break, and thermal mass are what you need to know.
construction, heating, insulation, walls
