Old 02-28-2018, 08:04 PM   #1
Interior panel removal
I just wanted to share something I learned while removing the interior panels on my international 3800.
I started using tin snips to remove the metal panels because they are all pressed under the windows. Then I used a grinding wheel to cut all the way through the panel, and I was destroying my wheels.
It saved me a few grinding wheels and lots of time!
I am sure most of you already did this or plan on doing it, but here it is. https://youtu.be/9FtMUAXHNoA
John.Smith is offline   Reply With Quote
Old 03-03-2018, 09:57 PM   #2
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
I started using the angle grinder but later went to an electric tin snips. Here is a video on how we did it.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 03-04-2018, 04:31 AM   #3
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
haha yep, i remember that lip that goes under the window. i cut all mine off with a cutting wheel I wasnt able to remove the cut off piece of mine until i raised the roof, and removed a **** load of rivets to fasten my new sheet metal to.
BurlKing is offline   Reply With Quote
Old 03-04-2018, 11:01 AM   #4
Chassis: Saf-T-Liner MVP ER
I don't see any need to remove the 1/4" strip that remains after I cut the panels. It's not in the way of anything and will be covered.
Cutting disk worked well, and fast.
Steve Bracken
Build Thread
